I'm trying to upgrade from 3.184 to 3.210 but am getting the following messages when compiling with 3.210 for a PIC18F452.
Error[300] Bootloader.c 119 : More info: Segment at 00000-07CBE (0000 used)
Error[300] Bootloader.c 119 : More info: Attempted to create: 07500-07FFE for #org
Error[126] Bootloader.c 119 : Invalid ORG range
I'd written a firmware updater which may/may not be compiled into the application. When NOT compiled in I include an "#ORG 0x7500, 0x7FFF {}" to reserve space for the updater. Previously this worked fine. Now with 3.210 I get the above messages.
Any ideas why this would happen?
Rob
USER_03
Posted: Mon Jan 31, 2005 4:22 pm
After some more searching of the forums I discovered my problem. I had "#device ICD=TRUE" set. Apparently with 3.184 this was either not an issue or the way ICD debug code is generated has changed.
