float from two int16's
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Sun Jan 30, 2005 10:03 am     Reply with quote
I've got to fix something blind without the hardware (always a pain!). Anyway it comes down to needing a float instead of a int32.
rough code:
int16 a;
int16 b;
float c;
c = a / b;
....................       R = pforce / sforce;
1DB4:  MOVFF  3D,41B
1DB8:  MOVFF  3C,41A
1DBC:  MOVFF  3F,41D
1DC0:  MOVFF  3E,41C
1DC4:  BRA    192E
1DC6:  MOVFF  02,41B
1DCA:  MOVFF  01,41A
1DCE:  MOVLB  0
1DD0:  BRA    1978
1DD2:  MOVFF  03,419
1DD6:  MOVFF  02,418
1DDA:  MOVFF  01,417
1DDE:  MOVFF  00,416
will this work OK or should i use
c = (float)a / (float)b; for a belts and braces approach? code:
....................       R = (float)pforce / (float)sforce;
1ECC:  MOVFF  3D,41F
1ED0:  MOVFF  3C,41E
1ED4:  RCALL  192E
1ED6:  MOVFF  00,41A
1EDA:  MOVFF  01,41B
1EDE:  MOVFF  02,41C
1EE2:  MOVFF  03,41D
1EE6:  MOVFF  3F,41F
1EEA:  MOVFF  3E,41E
1EEE:  RCALL  192E
1EF0:  MOVFF  41D,421
1EF4:  MOVFF  41C,420
1EF8:  MOVFF  41B,41F
1EFC:  MOVFF  41A,41E
1F00:  MOVFF  03,425
1F04:  MOVFF  02,424
1F08:  MOVFF  01,423
1F0C:  MOVFF  00,422
1F10:  BRA    1966
1F12:  MOVFF  03,419
1F16:  MOVFF  02,418
1F1A:  MOVFF  01,417
1F1E:  MOVFF  00,416
I would hope both of these would give me exactly the same result, is the compiler doing some good optimisation for me which I am overriding with the cast?
Keep well all,
Will
Charlie U
PostPosted: Sun Jan 30, 2005 10:57 am     Reply with quote
Will,
You could try your tests with a quick and dirty program on the simulator in MPLAB to confirm your results.
If you can't do that, I would definitely cast the variables before the divide. Look at one example: if a < b then the divide using ints should yield 0, while the divide with floats should yield a number between 1 and 0 in floating point notation.
Will Reeve
PostPosted: Sun Jan 30, 2005 11:31 am     Reply with quote
I wondered if some automatic casting would happen? I know CCS has some strange rules with casts. I haven't used a float for several years!
Charlie U
PostPosted: Sun Jan 30, 2005 3:45 pm     Reply with quote
Don't get your hopes up. I have learned the hard way that I should always make an explicit cast when I want thing to work out correctly. Don't rely on automatic/assumed casting.
In the case that you have mentioned, I just ran it on the simulator, and without the cast, the division is performed as int16 first, then the result is cast to a float. So, 2/4 = 0.00. If you cast both a and b to float, then divide, the result is 0.500. I tried this with a few values and the result is the same, int16 division then cast.
So, in your case, since you need to make the change "blind" and need the highest probability of success, cast first, then divide.
Will Reeve
PostPosted: Mon Jan 31, 2005 6:25 am     Reply with quote
Thanks. I really should install MPLAB again. When I switched to the CCS IDE I never went back. MPLAB never got installed on my new PC.
SherpaDoug
Re: float from two int16's
PostPosted: Mon Jan 31, 2005 8:43 am     Reply with quote
Will Reeve wrote:
int16 a;
int16 b;
float c;
c = a / b;
As I read K&R this should do a 16 bit integer divide producing an integer result which is then cast to a float. I assume that is NOT what you want.
If you want the compiler to do something else you must tell it what you want!
