Problem: 18LF242 keeps resetting (POR)
Michi
PostPosted: Thu Apr 10, 2003 8:26 am     Reply with quote
Having recently upgraded from using PCH 3.100 (within PCWH IDE) to PCH 3.150 (within MPLAB 6.13) I am getting a weird problem (with a 18LF242).
The code below resets the PIC about once per second and does not reach the following line:
printf("Hello "); in function init_all()
When I remove the ISR...
#int_RB
RS232_interrupt()
..it all works fine. As you can see, no interrupts are enabled.
The watchdog is disabled and I have tested the restart_cause() value and this points to a normal POR (0x0C).
Any help pointing me in the right direction is greatly appreciated. Thanks.
The code attached below has been cut down from about 90\% ROM usage to the following while still showing the problem explained above:
#include <18F242.H>
#device *=16
#fuses HS,PROTECT,NOOSCSEN,NOBROWNOUT,NOWDT,WDT128,PUT,CCP2C1,STVREN,NODEBUG,NOLVP,NOWRT,WRTD,NOWRTB
#use delay(clock=3686400)
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, errors)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#PRIORITY ext, rb
// map registers:
#bit POR = 0xFD0.1
#bit BOR = 0xFD0.0
#bit RI = 0xFD0.4
#byte port_b = 0xF81
#bit RBIF = 0xFF2.0
// global variables:
int last_b;
short CTS_RTS;
short CTS_high=false;
short char_received=false; // flag: incoming data over RS-232
// FUNCTION PROTOTYPES:
void activate_LED(short state);
void init_all(void);
// - M A I N -
main()
printf("RESET: \%X ",restart_cause());
bor=1;
ri=1;
switch ( restart_cause() )
case NORMAL_POWER_UP:
init_all();
por=1;
while(1) // loop forever...
void init_all(void)
set_tris_A(0b00011001);
set_tris_B(0b00101111);
set_tris_C(0b10011001);
output_high(PIN_C5); // LED on
delay_ms(150);
output_low(PIN_C5); // LED off
delay_ms(255);
activate_LED(1);
printf("Hello ");
// last_b=port_b; // read port_B to reset RBIF (undefined after POR)
// RBIF=0; // clear RBIF flag
// char_received=false;
// enable_interrupts(INT_RB);
// disable_interrupts(GLOBAL);
switch (state)
case 1:
case 0:
#int_RB
RS232_interrupt() // interrupt on PIN change
// RB4..7 can cause an RB interrupt:
// RB4 is output hence cannot cause an interrupt in this application
// RB5 is defined as input (parallel to RXD)
// RB6 is I/O-4 (defined normally as output)
// RB7 is I/O-3 (defined normally as output)
int changes;
short int found_int;
changes=last_b ^ port_b;
last_b=port_b;
found_int=false;
if (bit_test(changes,6))
found_int=true;
if (bit_test(last_b,6)) // RB6 = I/O-4 = CTS changed from low to high
if (CTS_RTS==1) // if handshaking enabled
CTS_high=true;
if (!found_int) // if no interrupt found assume it is...
{ // ...RS232 data arriving
char_received=true; // (fast changing state of RB5 makes it difficult to detect)
activate_LED(1); // Status LED on
___________________________
Original Post ID: 13578
Michi
switch () { } statement causes trouble (Compiler problem?)
PostPosted: Thu Apr 10, 2003 10:28 am     Reply with quote
I have narrowed it down to some odd code being produced when the switch (state){} is used.
The code further below without the switch statement works fine.
Any ideas?
THIS RESETS EVERY SECOND OR SO:
.................... activate_LED(int state)
.................... // output_high(PIN_C5); // LED on
.................... switch (state)
00CE: MOVF 1D,W
00D0: ADDLW FE
00D2: BTFSC FD8.0
00D4: GOTO 00EA
00D8: ADDLW 02
00DA: GOTO 00EC
.................... case 1:
.................... output_high(PIN_C5); // LED on
00DE: BSF F8B.5
.................... break;
00E0: GOTO 00EA
.................... case 0:
.................... output_low(PIN_C5); // LED off
00E4: BCF F8B.5
00E6: GOTO 00EA
00EA: RETLW 00
00EC: BTFSS 0D.7
00EE: GOTO 00F8
00F2: MOVFF FF2,0E
00F6: BCF FF2.7
00F8: ADDWF FE8,W
00FA: ADDLW 19
00FC: MOVWF FF6
00FE: MOVLW 01
0100: MOVWF FF7
0102: BTFSC FD8.0
0104: INCF FF7,F
0106: TBLRD*-
0108: MOVF FF5,W
010A: MOVWF FFA
010C: TBLRD*
010E: MOVF FF5,W
0110: BTFSS 0D.7
0112: GOTO 011A
0116: BTFSC 0E.7
0118: BSF FF2.7
011A: MOVWF FF9
011C: DATA E4,00
011E: DATA DE,00
.................... // - M A I N -
.................... main()
0208: CLRF FF8
THIS WORKS:
This is what it looks like when the switch (state) {} part is commented out.
0004: BSF F8B.5
0006: RETLW 00
01B6: CLRF FF8
Original Post ID: 13585
Re: switch () { } statement causes trouble (Compiler problem
PostPosted: Thu Apr 10, 2003 12:06 pm     Reply with quote
:=I have narrowed it down to some odd code being produced when the switch (state){} is used.
I don't have PCH so I can't help too much, but CCS does
have problems with switch statements sometimes.
From the versions page:
3.066 A optimization bug with switch..case 0 in some programs is fixed
3.143 A bug was fixed that occured with nested switches across a 64K boundry
As work-around, I suggest using if-else statements.
Original Post ID: 13588
Michi
Replacing "switch/case" with "IF" produc
PostPosted: Thu Apr 10, 2003 1:20 pm     Reply with quote
:=:=I have narrowed it down to some odd code being produced when the switch (state){} is used.
:=I don't have PCH so I can't help too much, but CCS does
:=have problems with switch statements sometimes.
:=From the versions page:
:=3.066 A optimization bug with switch..case 0 in some programs is fixed
:=3.143 A bug was fixed that occured with nested switches across a 64K boundry
:=As work-around, I suggest using if-else statements.
Thanks for your reply.
That seems to work - unfortunately I wasted 2 days of gradually narrowing down the fault.
I'll let CCS know about it...
Original Post ID: 13590
R.J.Hamlett
Re: Replacing "switch/case" with "IF" pr
PostPosted: Thu Apr 10, 2003 3:03 pm     Reply with quote
:=:=:=I have narrowed it down to some odd code being produced when the switch (state){} is used.
:=:=I don't have PCH so I can't help too much, but CCS does
:=:=have problems with switch statements sometimes.
:=:=From the versions page:
:=:=3.066 A optimization bug with switch..case 0 in some programs is fixed
:=:=3.143 A bug was fixed that occured with nested switches across a 64K boundry
:=:=As work-around, I suggest using if-else statements.
:=Thanks for your reply.
:=That seems to work - unfortunately I wasted 2 days of gradually narrowing down the fault.
:=I'll let CCS know about it...
Add a 'default' statement to your switches.
The compiler switches the way it generates the code if this is present.
Original Post ID: 13594
