Anyone have any pointers on migrating code from a 16C73 to a 16F873?
I have a fairly simple program that works fine on a 73 but doesn't do anything on an F873.
Thanks,
-Mike
Posted: Thu Jan 27, 2005 11:48 pm
The most likely reason is that the 16F873 is shipped with Low
Voltage Programming enabled. So you need to disable it by
adding NOLVP to the end of your #fuses statement.
turbo2ltr
Posted: Thu Jan 27, 2005 11:56 pm
Just figured it out.. My Picstart Plus Programmer is too old!!
The programing doesn't fail, but it doesn't actually program either.
