Unused Ports
sandy wilson
Unused Ports
PostPosted: Thu Apr 10, 2003 2:54 am     Reply with quote
I know this has been answered somewhere else but I've done a search and can't find it. What is the best way to leave unused ports on the 16F877. Set them as outputs?, inputs?, Outputs and loaded with a resistor tied high/low?
Any suggestions
Sandyw
___________________________
Original Post ID: 13572
Sherpa Doug
Re: Unused Ports
PostPosted: Thu Apr 10, 2003 6:55 am     Reply with quote
:=I know this has been answered somewhere else but I've done a search and can't find it. What is the best way to leave unused ports on the 16F877. Set them as outputs?, inputs?, Outputs and loaded with a resistor tied high/low?
:=Any suggestions
:=Thanks
:=Sandyw
I generally leave them open as outputs. That way they are not susceptable to noise and are available as diagnostic outputs or for future expansion. If you have space you might even run them to test points.
Original Post ID: 13574
Neutone
Re: Unused Ports
PostPosted: Thu Apr 10, 2003 8:39 am     Reply with quote
:=:=I know this has been answered somewhere else but I've done a search and can't find it. What is the best way to leave unused ports on the 16F877. Set them as outputs?, inputs?, Outputs and loaded with a resistor tied high/low?
:=:=Any suggestions
:=:=Thanks
:=:=Sandyw
:=I generally leave them open as outputs. That way they are not susceptable to noise and are available as diagnostic outputs or for future expansion. If you have space you might even run them to test points.
Microchip has some application notes reguarding low power operations that cover this topic. Inputs (floating) consume more power.
Original Post ID: 13579
R.J.Hamlett
Re: Unused Ports
PostPosted: Thu Apr 10, 2003 10:02 am     Reply with quote
:=Any suggestions
:=Thanks
Either set them as inputs, and provide an external resistor pull up/down, or set them as outputs.
You do not want a pin to float. The section of the chip data sheet, dealing with the 'sleep mode', covers the best way to set pins.
Original Post ID: 13583
Re: Unused Ports
PostPosted: Thu Apr 10, 2003 12:38 pm     Reply with quote
I set them as outputs, and set them low. That way, they're
not floating inputs, which could cause noise inside the PIC,
and as low-level outputs, they can't source any current if
something accidently touches the pins (such as a scope ground
lead, a screwdriver, etc.)
If you want some PIC archives other than this group, go here:
<a href="http://groups.google.com/advanced_group_search" TARGET="_blank">http://groups.google.com/advanced_group_search</a>
Set the group to comp.arch.embedded.piclist
(or to get more articles, set it to comp.arch.embedded.*)
Then in the box for phrases, put: unused inputs
There are several opinions on it, but I like my method best,
for the reasons given above.
Original Post ID: 13589
sandy wilson
Re: Unused Ports
PostPosted: Fri Apr 11, 2003 1:48 am     Reply with quote
Thank you everbody for your help.
Sandy
Original Post ID: 13600
