young
16c745 printf |
Posted: Wed Dec 22, 2004 1:44 pm |
In this 16c745 chip there is RX, TX as well as D+, D-, I think they all use printf, out, puts and getc, gets() to send and receive data from another computer or PIC, so how to separate them, I mean how can I know it is RS232 communication or USB communication? an dHow can specify to do RS232 communication and USB communication?
By the way, My best wishes for a Merry Christmas and Happy new year for every one in this forum, special thanks to Mark, PCM, SherpaDoug, rwyoung, dyeatman,ckielstra,Humberto, John Morley, rnielsen, Haplo, padamo, etc.......... Thank you for helping me when I was lost in my PIC advantures. I find a lot of fan to being with you! and Hope you guys continue to helping me in the coming new year! |
Posted: Wed Dec 22, 2004 2:13 pm |
Look in the CCS manual for functions that work with the RS232 pins,
such as printf, putc, getc, kbhit, etc.
Look in the CCS example file, USB.C, for functions that work with
the USB pins, such as usb_puts, usb_gets, usb_kbhit, etc. |
hillcraft
Joined: 22 Sep 2003 Posts: 101 Location: Cape Town (South africa)
USB Commands |
Posted: Thu Dec 23, 2004 12:35 am |
USB is not documented in the manuals. USB does not use the standard RS232 print and get functions.
Here is a code snippet that shows the difference.
while (true) {
cKey = 0;
if (kbhit(PORT_PC))
cKey = fgetc(PORT_PC);
usb_put_packet(1, USB_OUT_DATA, USB_EP1_TX_SIZE, TOGGLE);
You must take a look at the USB drivers and examples supplied with CCS.
Another thing to do to get going quickly is to study the HID USB implentation. All the documents are available for download at www.usb.org |
young
Posted: Wed Jan 26, 2005 8:21 am |
usb_puts(int8 endpoint, int8 * ptr, int16 len,int8 packet_size,int8 timeout);
usb_gets(int8 endpoint, int8 * ptr, int8 max);
usb_put_packet(int8 endpoint, int8 * ptr, int8 len,PID_TOGGLE tg1);
usb_get_packet(int8 endpoint, int8 * ptr, int8 max);
I learn from the sample to send data as int8 and the function are defined as int8.
first of all, all data all define as int8 *ptr, this is good for int8 data, how about char string[length], if I want to send data as "this is a test for usb", how should I do it,
second what is the difference between usb_put_packet() and usb_puts();
usb_gets() and usb_get_packet(), please provide short examples |
Mark
Posted: Wed Jan 26, 2005 8:29 am |
young wrote: | usb_puts(int8 endpoint, int8 * ptr, int16 len,int8 packet_size,int8 timeout);
char and int8 are the same for CCS so no problem. But had there been one, you could cast the pointer to the data as (int8*) and adjusted the length to reflect the actual number of bytes being sent. |
young
Posted: Wed Jan 26, 2005 8:41 am |
Thank you Mark:
usb_put_packet() sends one packet to the host, a packet is 8 byte maximum right, so if I send some string less that 8 byte, I should use usb_put_packet(), if I am sending some string large than 8 byte as "try usb123.9", I should use
char data[13]="try usb123.9"
usb_puts(EP1,(int8*)data,13,2,50);
because data has 13 byte include end of the string, and since it is 13, it will be in 2 packets, and timeout could be what ever? Am I right, please correct me? |
Mark
Posted: Wed Jan 26, 2005 8:54 am |
I haven't used the CCS USB (or any other except the FTDI chip) so I will let someone else answer that. |
young
Posted: Wed Jan 26, 2005 10:47 am |
Hi: hillcraft and PCM:
Would you please give some advice on this question? I really get confused by this four functions and the relationship between packet and message, and byte? |
young
Posted: Wed Jan 26, 2005 12:09 pm |
It looks like that packet_size is a number from 0-8
for the exmple I gaven it should be
usb_puts(EP1,data,packet_size,0); size could be any number from 1 to 8, right? |
