How to read output.
John_Rio
How to read output.
PostPosted: Sat Jan 22, 2005 1:58 pm     Reply with quote
I'am new in using the C & CCS compiler.
I have made a program the sets or clears outputs on the pic.
how can i read the actual state on a pin.
i tried:
if (pin_b4) do_what_ever; else do_somthing_else;
But it doesent work.
It's easy in assembler, so it should be possible here too?
Please help..
John
rwyoung
PostPosted: Sat Jan 22, 2005 2:23 pm     Reply with quote
if (input(PIN_B4))
   // do something impressive
is one way to do things. Another is to create a #byte and #bit pragma and access the pin that way. Need to #use fast_io() or #use fixed_io() if you #byte/#bit access the ports. input() will work with #use standard_io(), #use fast_io() and #use fixed_io()
Rob Young
John_Rio
PostPosted: Sat Jan 22, 2005 2:30 pm     Reply with quote
I already tried the one you mentione here if (input(pin_b4) ....
The problem is that this sets the pin as an input.
I am looking for a way to read the actual output.
John
rwyoung
PostPosted: Sat Jan 22, 2005 2:54 pm     Reply with quote
So what you are trying to do is readback the port register some time after altering the state of the output pin.
Have you tried (assuming PORTA on PIC16F877A, adjust to taste)
#byte PORTA = 0x05
#bit PINA0 = PORTA.0
#use fast_io(A)
... more code
set_tris_A(0x00); // all outputs
PINA0 = 1; // set pin high
// do many things here and loose track of how pin was set
if (PINA0)
   // do something wonderful
I haven't tested this code myself.
Rob Young
John_Rio
PostPosted: Sat Jan 22, 2005 3:22 pm     Reply with quote
Thanks a lot.
That did it.
#bit powerbit=0xF81.4
if (powerbit) Outbuffer[5]='0'; else Outbuffer[5]='1';
I'am using 18F452 so i had to change the register address.
Thanks a lot.[/list]
