? in a text string "xxx ?" compiles to "xxx ?
stoppsm
PostPosted: Wed Jan 19, 2005 3:08 am     Reply with quote
Have a problem with using a question mark "?" in a text string.
Example source: printf(lcd_putc, "ready ?"); // remark ready?
Code compiled:
List file: printf(lcd_putc, "ready ??); // remark ready??
The list file duplicates the '?' always and if there was a character after this that is overwritten too ie ?" = ??.
This issue occurs at all ? characters and usually has no effect on the text string printed, however occasionally it does corrupt the text message.
Can anyone advise why this happens and a solution to the issue. Mad
CCS version 3.25
PostPosted: Wed Jan 19, 2005 8:35 am     Reply with quote
We can check this problem for you if we know the correct version
number. There is no version "3.25". See the list of versions here:
http://www.ccsinfo.com/versions.shtml
To find the compiler version, look at the top of the .LST file
for your project. It will be a number such as 3.191, 3.216, etc.
stoppsm
PostPosted: Thu Jan 20, 2005 2:48 am     Reply with quote
The version is PCM 3.178
PostPosted: Thu Jan 20, 2005 4:02 pm     Reply with quote
I tested it with PCM vs. 3.178, for a 16F877. It appears to just be a
bug in the .LST file output. The ASM code looks OK. You can see
below that it has the space (0x20) and the ? (0x3F) character, followed
by the string terminator (0x00).
0004 100A       00009 BCF    0A.0
0005 108A       00010 BCF    0A.1
0006 110A       00011 BCF    0A.2
0007 0782       00012 ADDWF  02,F
0008 3472       00013 RETLW  72
0009 3465       00014 RETLW  65
000A 3461       00015 RETLW  61
000B 3464       00016 RETLW  64
000C 3479       00017 RETLW  79
000D 3420       00018 RETLW  20
000E 343F       00019 RETLW  3F
000F 3400       00020 RETLW  00
Here's the test program that I used:
#include <16F877.H>
#use delay(clock = 4000000)
#include <lcd.c>
With vs. 3.178, it gives double question-marks in the list file:
0000                00633 .................... printf(lcd_putc, "ready ??);
With vs. 3.216, it doesn't do that anymore, but it leaves off the closing double-quotation mark.
0000                00650 .................... printf(lcd_putc, "ready ?);
It's a recurring cosmetic bug and it should be fixed. You should report it to CCS tech support.
