Struct to eeprom write routine, saving only different bytes.
future
PostPosted: Mon Jan 10, 2005 3:54 pm     Reply with quote
This routine was already posted by me in the past.
Now I want it to save only the modified bytes, but it doesnt work. Only a test to verify if the data is different was added.
Did I something wrong?
    if(!EECON1bits.WR)
     if(eeprom_count<sizeof(cfg))
        EEADR=eeprom_count;
        EEDATA=*(&cfg+EEADR);
   if(EEDATA!=read_eeprom(EEADR))
            disable_interrupts(GLOBAL);
           EECON1bits.EEPGD=0;           // point to data memory
           EECON1bits.WREN=1;            // enable writes
           EECON2=0x55;
           EECON2=0xAA;
           EECON1bits.WR=1;              // begin write
        eeprom_count++;                  // increment index pointer
 else {
        eeprom_count=0;
        EECON1bits.WREN=0;               // disable writes
Thomas Blake
Re: Struct to eeprom write routine, saving only different by
PostPosted: Mon Jan 17, 2005 12:25 pm     Reply with quote
Why not use the CCS functions? Using CCS functions,
if (read_eeprom(i) != n) write_eeprom(i, n);
where i is the address and n is the data, works fine as a conditional eeprom write for any purpose.
But this reminds me of something I've wanted to ask the forum - does the Microchip EEPROM write algorithm automatically not do equal overwrites, as part of its endurance-enhancement process?
