FYI: RS232 USART RX/TX gotcha
ghanka
PostPosted: Mon Jan 17, 2005 11:00 am     Reply with quote
If you inadvertantly set the RX bit to output (TRIS_C.7=0), then anything the USART sends out the TX port will also show up on the RX port, but time-shifted two bit times earlier.
Debugging this problem can be truly fiendish.
gordon
PostPosted: Mon Jan 17, 2005 11:28 am     Reply with quote
Thanks!
But it helps even more when you are specific by also posting the processor type and the chip hardware revision number....
Mark
PostPosted: Mon Jan 17, 2005 12:58 pm     Reply with quote
Wow, so the PIC still receives even though the pin is an output Question
