Trying to work a set of 4 16x16 dot matrix LED displays
Goto page 1, 2  Next
Sugiman
PostPosted: Thu Jan 13, 2005 2:51 am     Reply with quote
Hi there,
I stumbled into this site while searching the web =)
I'm pretty much a beginner with PIC-C programming so take it easy on me please hehe. Before I forget, I'd also appreciate any links or sites I could go to for more information as well.
Here's what I've been asked to do. First, take a board (which has already been made - using PIC16F876) and set up a key matrix on it (4x4). With the help of a co-worker, I was able to hijack the dipswitch I/O's and use that for the keypad.
The next step is to use the same board to work the above mentioned LED matrix display. They are all set up in serial (it's a spare part from something that looked quite old.)
My basic question is how exactly does the data get to the display? I've heard about an intermediary chip that is involved. Did I mention that I work in Japan and none of the programmers speak English well enough to explain these things? Shocked
Also, how many ports would probably be needed for the display?
Lastly, (or maybe not, there will be more later on I bet) could I get a kickstart in the right direction for coding?
Thanks!
I'm not sure if I gave enough info, if not, please let me know what you need to know. It's been kinda frustrating trying to wrap my head around both circuitry and PIC-C
Mark
PostPosted: Thu Jan 13, 2005 7:20 am     Reply with quote
So this is a board built for some other purpose and you are trying to adapt it to a new purpose? We don't have a schematic for it so unless you can describe the ciruit, help you will get will be pretty basic.
Without knowing what the part is, you aren't going to get any help.
We can't answer that because we have no idea what you have, even though we do speak English Laughing
Are you using the CCS compiler?
Sugiman
PostPosted: Thu Jan 13, 2005 7:45 am     Reply with quote
Thanks for the response. =)
I'll try to get a schematic and some more info about the dot matrix LED's.
Please let me know any other information you might need.
Mark
PostPosted: Thu Jan 13, 2005 7:49 am     Reply with quote
What do you want to do with it?
Sugiman
PostPosted: Thu Jan 13, 2005 7:54 am     Reply with quote
Using the keypad, make a scorer for Table Tennis. 2 of the 16x16 LED's for each player. The buttons would raise or lower the score with a reset button that clears the scores if depressed for more than 1 second.
The LED's would have to be the main loop I'm guessing, in order to constantly show the score, with interrupts to scan the keys. Not entirely sure though.
Sugiman
PostPosted: Sun Jan 16, 2005 6:50 am     Reply with quote
I've uploaded a copy of the schematic to my msn homepage. It's under the Jan 16 photo album
Still working on finding info about the LED matrix
edit: forgot to put the url =P
http://spaces.msn.com/members/sugi1701
Mark
PostPosted: Sun Jan 16, 2005 8:44 am     Reply with quote
Well I couldn't read it (too small) so I saved it to my computer and it was still to fuzzy to read.
Sugiman
PostPosted: Sun Jan 16, 2005 7:58 pm     Reply with quote
OK sorry about that. I won't shrink it much this time and post it again when I get home.
Sorry for all the trouble Sad
PostPosted: Mon Jan 17, 2005 6:17 am     Reply with quote
Well apparently the spaces homepage thing resizes the pictures to around 25KB automatically.
Here's a pdf file that has the general schematic of the board.
http://www.daisendenshi.com/Receiver/R02R04manual.pdf
Sugiman
PostPosted: Mon Jan 17, 2005 6:34 am     Reply with quote
oops, forgot to sign in before posting the previous post about the schematic, so "Guest" is me
Embarassed
Mark
PostPosted: Mon Jan 17, 2005 6:50 am     Reply with quote
And the PDF contains 8 blank pages.
Sugiman
PostPosted: Mon Jan 17, 2005 7:28 am     Reply with quote
*sigh* I'm really sorry for all the trouble with this.
Must be because the PDF is in Japanese.
Well, not sure what to do now with this. Do you know a place I can post that picture at it's normal size?
Sugiman
PostPosted: Mon Jan 17, 2005 8:11 am     Reply with quote
OK, I think I have the basic schematic here now. http://spaces.msn.com/members/sugi1701
And it's pretty basic. Working on a more detailed list of what each port on the CPU goes to
edit: ok got a pic of the CPU as well. I don't have the board with me at home so I'm not sure what the ports do that I didn't mark. On the main Schematic is seems that they're connected to something, but I can't figure out what they are
Sugiman
PostPosted: Fri Jan 21, 2005 7:39 pm     Reply with quote
Did the new pictures help at all?
rwyoung
PostPosted: Fri Jan 21, 2005 8:27 pm     Reply with quote
The overall schematic is still much too small and low-res to be of any use at all.
Rob Young
Goto page 1, 2  Next
Page 1 of 2
