setup ccp2
eaton
setup ccp2
PostPosted: Sun Jan 16, 2005 2:11 pm     Reply with quote
Using a PIC18f252. My compiler gives me the unidentified identifier error when compiling. set_up_ccp1 will compile ok. same for set_duty_pwmX.
set_duty_pwm1 is ok. set_duty_pwm2 won't work. Any insights?
thanks
Mark
PostPosted: Sun Jan 16, 2005 2:34 pm     Reply with quote
Post a small test program demonstrating the problem. Include the processor and compiler version. Make sure you use the code button when posting code.
PostPosted: Sun Jan 16, 2005 4:08 pm     Reply with quote
The actual function name is different from the one given in your post.
I tested this line with PCH vs. 3.188 and it compiled without error:
set_pwm2_duty(0x55);
