beck
Picdem.net and CCS and SMTP |
Posted: Sun Jan 16, 2005 10:39 am |
I would like a mail send with my Picdem.net by SMTP. There is a software for the CCS Kompiler. The software known to me of IOSOFT doesn't work. Has anybody of Microchip transcribed TCP/IP Stack for CCS?
Best Regards
Matthias Beck |
dyeatman
CCS has it |
Posted: Sun Jan 16, 2005 11:13 am |
CCS has a TCP/IP stack converted for CCS.
If you are a registered CCS user send them an email they will send it to you.
Also, Jeremy Benthams book TCP/IP Lean has CCS based TCP code in it.
Try this link for more info:
http://www.ccsinfo.com/forum/viewtopic.php?t=18357
BTW, I have seen the IOSOFT code used and it worked so you may not be doing something right. Why dont you ask IOSOFT? |
Posted: Sun Jan 16, 2005 11:39 am |
> Hello,
> I have a problem with your software.
> I use the following surroundings:
> - picdem.net
> - CCS compiler PCH 3,214
> - PWeb v2.62
> Settings:
> -------- - p18web.c
> /* TCP protocols: enabled if non-zero */
> #define INCLUDE_HTTP 1 // Enable HTTP Web server
> #define INCLUDE_SMTP 1 // Enable SMTP email client
> #define INCLUDE_POP3 0 // Enable POP3 email client
> /* UDP protocols: enabled if non-zero */
> #define INCLUDE_DHCP 0 // Enable DHCP auto-confiuration
> #define INCLUDE_TIME 0 // Time client: polls server routinely
> /* Other utilities */
> #define INCLUDE_WLAN_SCAN 0 // Set non-zero to scan for WLAN Access
> Points // (ER21 must be enabled, SMTP disabled)
> /* Low-level drivers: enabled if non-zero */
> #define INCLUDE_ETH 1 // Ethernet driver
> #define INCLUDE_WLAN 0 // Wireless LAN card driver
> #define INCLUDE_LCD 1 // Set non-zero to include LCD driver
> #define INCLUDE_CFG 1 // Set non-zero to include IP & serial
> num config
> #define ER21 0 // Set non-zero if ER21 WLAN board (0
> if PICDEM) #define ADDRLATCHED 0 // Set non-zero for ER22
> (ER21 must also be set) --------------------------------------------
> -------- - p18_tcpc.c
> #define MAILSERVER_ADDR 194,25,134,25
> #define CLIENT_DEBUG 1
> My problem:
> - The program starts
> - The internet page is represented correctly.
> - After "Press pushbutton to run SMTP client"
> debug screen
> SMTP start
> ARP TCP //some seconds wait
> FAILED //Answer of line 234 from p18_tcpc.c
> DISCONNECTED //Answer of line 282 from p18_tcpc.c
I had put the question to IOSOFT and I got the answer shall myself after an old software (version 2.21) uses the fault suchen.Ich and the fault is very difficult.
Here one statement
> Where is the problem?
> With another web server (Atmel) all einwandfre works. So the line
> path to the provider and the IP address is all right.
Best Regards
Matthias Beck |
beck
Posted: Sun Jan 16, 2005 11:44 am |
Excuse me, I didn't have me log-in.
Here one statement
> Hello,
> - picdem.net
> - PWeb v2.62
> Settings:
> -------- - p18web.c
> num config
> My problem:
> debug screen
> SMTP start
Best Regards
Matthias Beck |
