simple question about floating pins
LaTech
PostPosted: Thu Jan 13, 2005 11:18 am     Reply with quote
i am using a pic for a school project. The pic I
m using is an overkill. I have about 8 pins not used. The code works fine when I run it, but I recall someone here saying I should never leave the pins floating.
So I should use a 10k pull down resistor and pull all the unused pins to ground?
SherpaDoug
PostPosted: Thu Jan 13, 2005 12:06 pm     Reply with quote
That will certainly work. Often people have a fixed PCB with no room for resistors. Then I tell then to make the pins outputs.
The reason not to leave pins open is at least twofold:
1) If the pin decides to sit halfway between 0 and 1 it can cause the input buffer to draw lots of current or oscillate, which consumes power, generates heat, and if oscillating, generates electrical noise.
2) Floating pins are more susceptable to static damage. This is likely only to damage the pin involved, but may also hurt other circuits on the chip.
Mark
PostPosted: Thu Jan 13, 2005 12:07 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=3861&highlight=unused+pins
LaTech
PostPosted: Thu Jan 13, 2005 12:35 pm     Reply with quote
Yep that answered the question, I did a search before i posted but the term 'floating' retrieved alot of number problems not pin problems.
Thanks again!
guest2
RE:
PostPosted: Sun Jan 16, 2005 6:26 am     Reply with quote
Maybe you should configure them as inputs instead, if you connect the output to ground inadvertently then you might short the +5 V line.
thanks
arun
Mark
Re: RE:
PostPosted: Sun Jan 16, 2005 8:41 am     Reply with quote
guest2 wrote:
thanks
arun
Now that is just plain silly Razz What if you inadvertently connected a pin you wanted to be an output to ground Question
Pullups/Pulldowns
PostPosted: Sun Jan 16, 2005 9:03 am     Reply with quote
FWIW, I agree with Mark.
As a matter of practice I NEVER EVER connect any I/O pins (even ones normally A/D) directly to +V or ground... If something happens, regardless of how inadvertantly (even a compiler error), to configure the pins incorrectly you destroy the chip.
I always use pullups or pulldowns in SIL resistor packages to minimize the room required. In real tight situations, being as small as they are, I have even soldered them directly to the pin connections on the bottom of the board so they don't require real estate.
