Setting W register as a function variable |
Posted: Thu Jan 13, 2005 2:51 pm |
I'm trying to optimize my code and I would like to know if there's any clean way to do this.
Let's assume that I'm using a function
void TRANSMIT(int8 data)
If I call it like this:
TRANSMIT(0x88);
I'll always get:
;----------------- TRANSMIT(0x88)
MOVLW 88
MOVWF 71 <---This is not necessary
CALL 108
Is there a way to force the variable to be W so there would not be a MOVWF everytime the function is called. (The MOVWF would be inside the function)??
Thanks |
Posted: Fri Jan 14, 2005 2:35 pm |
I tryed using #inline and it didn't help with the problem.
You could use a macro. If you use a macro, then it
doesn't make a function call. It just replicates the code
in each instance. I don't know if that's going to help your
efficiency problem, though.
The program below creates this ASM code:
Code: | 0000 00296 ....................
0000 00297 .................... TRANSMIT(0x55);
0012 3055 00298 MOVLW 55
0013 1E0C 00299 BTFSS 0C.4
0014 2813 00300 GOTO 013
0015 0099 00301 MOVWF 19
0000 00302 .................... TRANSMIT(0xAA);
0016 30AA 00303 MOVLW AA
0017 1E0C 00304 BTFSS 0C.4
0018 2817 00305 GOTO 017
0019 0099 00306 MOVWF 19 |
Code: | #include <16F877.H>
#use delay(clock = 4000000)
putc(data);
#define TRANSMIT(data) putc(data)
TRANSMIT(0x55);
TRANSMIT(0xAA);
dperron
Posted: Fri Jan 14, 2005 3:56 pm |
The problem with #define is that it's limited to only 1 line, you cannot do a multiline macro with it.
I really wished there were some way to set W a the variable...
So it's not so trivial after all... |
Posted: Fri Jan 14, 2005 4:20 pm |
Quote: | The problem with #define is that it's limited to only 1 line, you cannot do a multiline macro with it. |
Actually you can, if you have a modern version of the compiler.
You can use the backlash symbol to indicate line continuation. Example:
// This macro transmits the data byte 4 times.
#define TRANSMIT(data) putc(data); \
putc(data); \
putc(data); \
putc(data) |
Posted: Sat Jan 15, 2005 11:25 am |
dperron wrote: | The problem with #define is that it's limited to only 1 line, you cannot do a multiline macro with it.
As PCM programmer has pointed out, you can have multi-line macros. You can also go further, and use a very rarely used feature of C, and have a multi-line macro, returning a value. If you generate a macro like:
#define from_locn(x) (temp=x,\
x=(x+1)%maxval,\
buffer[temp])
The code will save 'x', increment it, and generate the remainder after division my the 'maxval' value (ideal for incrementing a buffer pointer), then return the contents of 'buffer[temp]', as the macro return value!.
The 'comma' seperator, as opposed to the normal semi-colon seprator, in C, allows multiple statements to be executed, and only returns the value of the last statement.
The macro language in C, can do a lot more than is often realised...
