PIC 16F877. Implementation of i2c master with interrupt.
Renato and Davide
PostPosted: Wed Nov 28, 2001 9:48 am     Reply with quote
Hello at everybody,
we have wrote this code:
#USE I2C(master, sda=PIN_C4, scl=PIN_C3, SLOW, NOFORCE_SW)
int i=0;
void main ()
i2c_start ();
#INT_SSP
void master()
i2c_write (buffer[i]); //buffer[0] = 0x0E (slave address)
if (i==21) i2c_stop ();
i++;
* The problem is that the instruction i2c_start() in main provokes an interrupt, but the i2c_write () doesn't cause interrupt, is it correct ? If it is correct what is the usefullness?
* We have seen that the i2c_write () returns 0 (ACK) when the slave address is correct, but this not cause new interrupt.
* We had test that if the instruction i2c_write is located in main it cause the interrupt:
void main ()
i2c_start (); //cause the interrupt
i2c_write (); //cause the interrupt
We do not understand the usefullness.
IDE Version = 2.32
PCB Version = 3.043
PCM Version = 3.043
Thank you for the support. Best regards
___________________________
Original Post ID: 1352
Tomi
Re: PIC 16F877. Implementation of i2c master with interrupt.
PostPosted: Wed Nov 28, 2001 11:51 am     Reply with quote
Bon giorno,
the i2c_write() function includes a wait state after moving the byte into SSPBUF (it waits for the end of the write cycle).
Try this instead of "i2c_write(buffer[i])" line:
bit_set(*0x14,4); // optional:the clock polarity instruction if it is necessary
*0x13 = buffer[i]; // direct write into SSPBUF
:=Hello at everybody,
:=we have wrote this code:
:=#USE I2C(master, sda=PIN_C4, scl=PIN_C3, SLOW, NOFORCE_SW)
:=int i=0;
:=void main ()
:= i2c_start ();
:=#INT_SSP
:=void master()
:= i2c_write (buffer[i]); //buffer[0] = 0x0E (slave address)
:= if (i==21) i2c_stop ();
:= i++;
:=* The problem is that the instruction i2c_start() in main provokes an interrupt, but the i2c_write () doesn't cause interrupt, is it correct ? If it is correct what is the usefullness?
:=* We have seen that the i2c_write () returns 0 (ACK) when the slave address is correct, but this not cause new interrupt.
:=* We had test that if the instruction i2c_write is located in main it cause the interrupt:
:=void main ()
:= i2c_start (); //cause the interrupt
:= i2c_write (); //cause the interrupt
:=We do not understand the usefullness.
:=IDE Version = 2.32
:=PCB Version = 3.043
:=PCM Version = 3.043
:=Thank you for the support. Best regards
Original Post ID: 1356
