Error[70] - No MAIN() function found
jd
PostPosted: Thu Jan 13, 2005 11:28 am     Reply with quote
I am trying to compile a simple project using MPLAB v7.00 and PCM version 3.212. This project consists of 2 c files main.c and simplefunc.c
and one header file simplefunc.h
here is my main.c code
/* main.c */
#include <12C671.h>
#include "simplefunc.h"
simple_func();
return;
here is the fimplefunc.h header file
/* simplefunc.h */
#ifndef __SIMPLE_FUNC_H__
#define __SIMPLE_FUNC_H__
void simple_func();
#endif
and here is the simplefunc.c file
/* simplefunc.c */
#include <12C671.h>
void simple_func()
int i = 0;
i = i * 1000;
return;
Now when I compile the code generates ERROR[70] and gripes that simplefunc.c doesn't have a main() function. How do I get around this error, does one need to include all additional c files in main.c files?
Any help would be greatly appreciated.
JD
PostPosted: Thu Jan 13, 2005 11:32 am     Reply with quote
JD,
Yes, you must "include" all files that will be used. This compiler does not have a linker...
Darren Rook
PostPosted: Thu Jan 13, 2005 11:49 am     Reply with quote
Also,
in MPLAB you can only have 1 C file in the Source File pane. If you have more than 1 it will try to compile each individually and then link them. I am not sure why - I haven't used MPLAB in a while does it still do this with CCS? It would be convenient if you could drop all your .C files in the Source File pane so you have easy access to them....
PostPosted: Thu Jan 13, 2005 12:02 pm     Reply with quote
Darren Rook wrote:
Also,
Yes I can have more that one .c file but it generates the error when building when it compiles each individual file (as you stated).
