internal oscillator
derya
internal oscillator
PostPosted: Thu Jan 13, 2005 9:21 am     Reply with quote
As I know, some PIC models have internal oscillator circuit and no need to assemble any external oscillator. Such models run with 4MHz frequency in general. Which models of PIC has internal oscillator? Is PIC16F648A has? If it has;Could you give me the example code?
Mark
PostPosted: Thu Jan 13, 2005 9:28 am     Reply with quote
Don't be lazy, go here:
www.microchip.com
SherpaDoug
PostPosted: Thu Jan 13, 2005 10:20 am     Reply with quote
Beware that most of the internal oscillators have poor accuracy and may not even be good enough for reliable serial communication. But if you are just making a talking Teddy bear they may be fine.
Mark
PostPosted: Thu Jan 13, 2005 10:22 am     Reply with quote
So far this poster wanted to generate a 1MHz PWM. If that is still their intention, it is not going to happen and 4MHz (not with a 25% duty cycle).
derya
it's okey
PostPosted: Fri Jan 14, 2005 2:15 am     Reply with quote
I have achieved to get 1MHz PWM signal with 1/4 duty cycle.
I used 20MHz oscillator and parameters are as following;
setup_timer_2(4, 4, 1);
set_pwm1_duty(1);
Thanks...
regall
Re: it's okey
PostPosted: Sat Jan 15, 2005 9:19 am     Reply with quote
derya wrote:
set_pwm1_duty(1);
Thanks...
tembel olmak yok derya biraz okuyacaksın calısacaksın . yok ole hemen kod falan istemek. Smile
PostPosted: Tue Jan 18, 2005 1:14 am     Reply with quote
Twisted Evil
