Oddity in latest 18F452 header file
PostPosted: Wed Jan 12, 2005 1:26 pm     Reply with quote
With the release of 3.215 or 3.216 (I think; not sure which), I found this in the 18F452.h device header:
long CCP_1;
#byte   CCP_1    =                      0x15
#byte   CCP_1_LOW=                      0x15
#byte   CCP_1_HIGH=                     0x16
#byte   CCP_1    =                      0xfbe
#byte   CCP_1_LOW=                      0xfbe
#byte   CCP_1_HIGH=                     0xfbf
Does this look odd to anyone else? Doesn't this essentially make the 0x15 and 0x16 specifications moot?
Jeff S.
Haplo
PostPosted: Wed Jan 12, 2005 4:21 pm     Reply with quote
This is from 3.190:
long CCP_1;
#byte   CCP_1    =                      0xfbe
long CCP_2;
#byte   CCP_2    =                      0xfbb
#byte   CCP_2_LOW=                      0xfbb
#byte   CCP_2_HIGH=                     0xfbc
Looks like they screwed up the header files again. Why they keep touching them, I don't know.
PostPosted: Wed Jan 12, 2005 4:46 pm     Reply with quote
Did someone report this bug to CCS?
rwyoung
PostPosted: Wed Jan 12, 2005 6:02 pm     Reply with quote
The duplication of CCP_1 is in the 18F6525 header also.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
Darren Rook
PostPosted: Wed Jan 12, 2005 8:19 pm     Reply with quote
It's a bit more complicated than that.
Haplo
PostPosted: Wed Jan 12, 2005 10:35 pm     Reply with quote
Please enlighten us! I'm very curious and anxious to know.
Darren Rook
PostPosted: Thu Jan 13, 2005 7:33 am     Reply with quote
The header files are re-generated with each release to incorporate any changes made to the devices.dat. An employee of CCS doesn't actually write, or edit, each header file.
Re: Oddity in latest 18F452 header file
PostPosted: Thu Jan 13, 2005 8:48 am     Reply with quote
long CCP_1;
#byte   CCP_1    =                      0x15
#byte   CCP_1    =                      0xfbe
Jeff S.
It was OK in V3.214 as you see here:
long CCP_1;
#byte CCP_1 = 0xfbe
I dumped V3.16 yesterday because delay_ms(1000) does not not work.
Fix one thing break two things... Progress like that should end up taking us back to version 1.0.
rnielsen
PostPosted: Thu Jan 13, 2005 12:44 pm     Reply with quote
V3.215 is correct. Luckily too. I'm designing a new project using the F452 and haven't installed 3.216 yet.
Thanks for the heads up.
Haplo
PostPosted: Thu Jan 13, 2005 4:19 pm     Reply with quote
Well that seems to be fixed now in the 'new' 3.216.
PostPosted: Fri Jan 14, 2005 6:28 am     Reply with quote
Well then, why do they keep touching the devices.dat file for these PIC's? Mad
Haplo
PostPosted: Fri Jan 14, 2005 7:23 am     Reply with quote
Well I think he's got you there, Darren Very Happy
Darren Rook
PostPosted: Fri Jan 14, 2005 8:55 am     Reply with quote
Even if you don't touch the .DAT files, all header files get re-generated for that release. The generater borked for some reason. If you have a problem I suggest e-mailing tech support.
PS - The .dat holds more information that's in the headerfile. It also includes information about debugging (ICD) and programming (Mach-X)
