Understanding serial behavior
Gerrit
PostPosted: Tue Apr 08, 2003 6:39 am     Reply with quote
Hello all,
Can someone explain to me how it works?
I use two interupts 1 serial 1 timer.
The timer has high priorety
The timer interupt can spend more time than the
length of a serial byte, but not more the 3 bytes.
What happens if timer and serial interupt happen at the same
time, and during timer interupt routine an other byte is received?
1 after timer routine I get 2 times an interupt for reading a serial byte.
2 after timer routine I get 1 time an interupt for reading a serial byte and no interupt until the next byte is received.
I know that it is not wise to spend that mutch time in an interupt, but that is not what I want to know.
Regards,
Gerrit
___________________________
Original Post ID: 13492
Neutone
Re: Understanding serial behavior
PostPosted: Tue Apr 08, 2003 8:41 am     Reply with quote
<font face="Courier New" size=-1>:=Hello all,
:=Can someone explain to me how it works?
:=I use two interupts 1 serial 1 timer.
:=The timer has high priorety
:=The timer interupt can spend more time than the
:=length of a serial byte, but not more the 3 bytes.
:=What happens if timer and serial interupt happen at the same
:=time, and during timer interupt routine an other byte is received?
:=1 after timer routine I get 2 times an interupt for reading a serial byte.
:=2 after timer routine I get 1 time an interupt for reading a serial byte and no interupt until the next byte is received.
:=I know that it is not wise to spend that mutch time in an interupt, but that is not what I want to know.
:=Regards,
:=Gerrit
You can increase the crystal speed, lower the baud rate or reduce the timer duration. Otherwise you will miss incomming bytes. The time it takes to handel a timer interupt and two serial interupts must be less than 2 byte periods.
Assume this is timer interupts over time
-T---------------------------------------T--
Assume this is serial interupts over time
S--------S--------S--------S--------S--------
Assume this is the duration of a timer interupt
TI----------
Assume this is the duration of a serial interupt
SI-
SI-TI----------SI-SI-
The second serial byte must be moved from the serial buffer before the third byte arrives.</font>
Original Post ID: 13495
R.J.Hamlett
PostPosted: Tue Apr 08, 2003 10:45 am     Reply with quote
:=Hello all,
You will have problems.
Firstly, it is the time in the timer interrupt, plus the time taken to handle the serial interrupt (and the latencies involved both in the hardware, and in saving/restoring the registers), that all have to be added together to get the 'worst case' scenario.
The second problem is that there are not three characters of buffer time available. Consider the situation where the receive register finishes a character one clock after the timer interrupt has occured...
You will lose data, and get the overrun error bit set.
Original Post ID: 13503
Gerrit Faas
PostPosted: Tue Apr 08, 2003 10:49 am     Reply with quote
Hi Neutone,
I understand that this example is not correct, but I have a problem with 3th party controler, and I want to isolate the problem.
What happens if the next situation was real:
the serial interupt only read 1 byte:
************ = time in the timer interupt
:=-T************----T--
:=--S--------S--------S--------S--------S--------
:=-TI----------SISI-TI---- is this the behaviour or
:=-TI----------SI---TI----
Regards,
Gerrit
:=<font face="Courier New" size=-1>:=Hello all,
:=:=Can someone explain to me how it works?
:=:=I use two interupts 1 serial 1 timer.
:=:=The timer has high priorety
:=:=The timer interupt can spend more time than the
:=:=length of a serial byte, but not more the 3 bytes.
:=:=What happens if timer and serial interupt happen at the same
:=:=time, and during timer interupt routine an other byte is received?
:=:=1 after timer routine I get 2 times an interupt for reading a serial byte.
:=:=2 after timer routine I get 1 time an interupt for reading a serial byte and no interupt until the next byte is received.
:=:=I know that it is not wise to spend that mutch time in an interupt, but that is not what I want to know.
:=:=Regards,
:=:=Gerrit
:=You can increase the crystal speed, lower the baud rate or reduce the timer duration. Otherwise you will miss incomming bytes. The time it takes to handel a timer interupt and two serial interupts must be less than 2 byte periods.
:=Assume this is timer interupts over time
:=-T---------------------------------------T--
:=Assume this is serial interupts over time
:=S--------S--------S--------S--------S--------
:=Assume this is the duration of a timer interupt
:=TI----------
:=Assume this is the duration of a serial interupt
:=SI-
:=SI-TI----------SI-SI-
:=The second serial byte must be moved from the serial buffer before the third byte arrives.</font>
Original Post ID: 13504
