Einly
| How to read eeprom card (telephone card) using PIC? |
Posted: Thu Jan 06, 2005 1:41 am |
I am using PIC 16f876 to read a telecard. I tried using i2c_read() to read it but the program hang. I suspect it is waiting for something to happen.
Below is my program:
#ifndef EEPROM_SDA
#define EEPROM_SDA PIN_C5
#define EEPROM_SCL PIN_C4
#endif
#include <16f876.h>
#fuses hs, nowdt, nolvp, noprotect
#use rs232(baud=115200,xmit=PIN_C6,rcv=PIN_C7,PARITY=N)
#byte PORTB=6
#byte PORTC=7
#use i2c(master,sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS byte
#define EEPROM_SIZE 256
void init_ext_eeprom();
void write_ext_eeprom(byte MSB_address, byte LSB_address, byte data);
byte read_ext_eeprom(byte MSB_address, byte LSB_address);
byte i;
byte MSB, LSB, data0;
byte result1;
byte b=0x53;
set_tris_b(0);
set_tris_c(0x84);
portc=0;
init_ext_eeprom();
output_high(PIN_B7);
output_low(PIN_B7);
do
printf("%x\n\r",b);
for(i=0;i<64;i++)
result1=read_ext_eeprom(0,i);
printf("%x \r",result1);
delay_ms(300);
}while(1);
void init_ext_eeprom() {
output_float(eeprom_scl);
output_float(eeprom_sda);
void write_ext_eeprom(byte MSB_address, byte LSB_address, byte data) {
i2c_start();
i2c_write(0xa0);
i2c_write(MSB_address);
i2c_write(LSB_address);
i2c_write(data);
i2c_stop();
delay_ms(11);
byte read_ext_eeprom(byte MSB_address,byte LSB_address)
byte data2;
i2c_start();
i2c_write(0xa0);
i2c_start();
i2c_write(0xa1);
data2=i2c_read(0);
i2c_stop();
return(data2);
I connect PIN C5 to SDATA of the telecard, PIN C4 to the SCLK of the telecard. Vcc of the telecard to 5V and GND to 0V.
My I know what should I do to correct my mistake? Can I use this method? Is there any address on the telecard that could not be read?
Thanks _________________ Einly |
Mark
Posted: Thu Jan 06, 2005 7:48 am |
| Those are probably smart cards. |
Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Posted: Thu Jan 06, 2005 10:03 am |
| not knowing the cards, do you have your pull up resistors on the SDA and SCL lines? .. 3.3K or so |
Mark
