why function in loop while(1) is not work? Please help me.
a
PostPosted: Thu Jan 06, 2005 4:31 am     Reply with quote
below is my sourcecode. i'm very confuse about why function in loop while is not work.
i'm try do...while(1) and while(1). it's not work. Sad Sad
#include <16F876.h>
#use delay(clock=3579545)
#use rs232(baud=9600, parity=N,xmit=PIN_B7,rcv=PIN_B7,bits=9)
#bit ninth_bit = RS232_ERRORS.7
#bit collision = RS232_ERRORS.6
#bit intf = 11.1
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <input.c>
#define RW PIN_A0
#define RS PIN_A1
#define EN PIN_A2
#define LED0 PIN_A3
#define LED1 PIN_A4
byte cou;
byte tmpsc[6];
int cloop,counterr;
int countloop;
int cerror;
long numchartrue=0;
long numcharfalse=0;
long countloopwhile=0;
void out_led(int i_led)
switch(i_led) // before after
{ // 4 3 4 3
case 0 : { output_high(LED1); output_low(LED0); break; } // 0 0 1 0
case 1 : { output_high(LED1); output_high(LED0); break; } // 0 1 1 1
case 2 : { output_low(LED1); output_low(LED0); break; } // 1 0 0 0
case 3 : { output_low(LED1); output_high(LED0); break; } // 1 1 0 1
default : { break; }
//because PIN_A4 is open Drain output must be toggle from it should be
//========================================LCD==================================
void busy_strobe(void)
OUTPUT_LOW(EN);
delay_us(2);
OUTPUT_HIGH(EN);
delay_us(2);
void write_strobe(void)
OUTPUT_HIGH(EN);
delay_us(2);
OUTPUT_LOW(EN);
delay_us(2);
void Command(void)
OUTPUT_LOW(RS);
OUTPUT_LOW(RW);
void wait_for_lcd_ready(void)
unsigned char busy_flag;
SET_TRIS_C(0XFF); //PORTD7 INPUT;
OUTPUT_LOW(RS); //SET FOR READ BUSY;
OUTPUT_HIGH(RW); //SET FOR READ BUSY;
busy_strobe();
busy_flag=(input_C() & 0x80);
while( busy_flag == 0x80)
OUTPUT_LOW(EN);
busy_strobe();
busy_flag=(input_C()&0x80);
OUTPUT_LOW(EN);
SET_TRIS_C(0x00); //PORTD7 OUTPUT;
void clear_lcd(void)
Command();
OUTPUT_C(0x01);
write_strobe();
wait_for_lcd_ready();
void cursor_off(void)
Command();
OUTPUT_C(0x0c);
write_strobe();
void init_lcd(void)
Command(); //add 240847
OUTPUT_C(0x38); //add 240847
write_strobe(); //add 240847
delay_ms(5); //add 240847
Command();
OUTPUT_C(0x38);
write_strobe();
delay_us(120); //add 240847
Command();
OUTPUT_C(0x0f);
write_strobe();
clear_lcd();
Command();
OUTPUT_C(0x02);
write_strobe();
cursor_off();
void Wchar(unsigned char char_)
OUTPUT_HIGH(RS);
OUTPUT_LOW(RW);
OUTPUT_C(char_);
write_strobe();
void gotoxy(unsigned char row,unsigned char col)
Command();
if (row==1) OUTPUT_C(0x80+col-1);
if (row==2) OUTPUT_C(0xc0+col-1);
write_strobe();
void Wcharxy(unsigned char row,unsigned char col,unsigned char data_)
gotoxy(row,col);
Wchar(data_);
void string_to_lcd(unsigned char row,unsigned char col,unsigned char *st)
unsigned char i,len;
len=strlen(st);
if (len>20) len=20;
gotoxy(row,col);
for(i=0;i<=len-1;i++)
Wchar(st[i]);
void int_to_lcd(unsigned char row,unsigned char col,int data_int)
unsigned char str[7];
sprintf(str,"%d",data_int);
string_to_lcd(row,col,str);
void long_to_lcd(unsigned char row,unsigned char col,long data_long)
sprintf(str,"%ld",data_long);
void hex_to_lcd(unsigned char row,unsigned char col,unsigned char data_hex)
unsigned char str[3];
sprintf(str,"%x",data_hex);
void float_to_lcd(unsigned char row,unsigned char col,float data_float)
sprintf(str,"%02.1f",data_float);
int8 find_parity(int8 data)
#asm
swapf data, W
xorwf data, F
rrf data, W
xorwf data, F
btfsc data, 2
incf data, F
movf data, W
andlw 1
movwf _return_
#endasm
void pbus_write(byte cha)
BYTE checksum,i;
int count,evencheck;
long cycles;
int er;
wcharxy(2,1,cha);
hex_to_lcd(2,10,cha);
delay_ms(200);
retry:
disable_interrupts(GLOBAL);
if(find_parity(cha)==0) { ninth_bit=0; }
else if(find_parity(cha)==1) { ninth_bit=1; }
putc(cha);
for(cycles=0;cycles<=2;cycles++)
if( !input(PIN_B7) )
goto error;
return;
error:
delay_us(100);
goto retry;
#int_RB
void checkserial(void)
byte data;
if(kbhit())
data=getc();
if (find_parity(data) == ninth_bit)
numchartrue++;
long_to_lcd(1,10,numchartrue);
output_low(PIN_B7); delay_us(50); output_high(PIN_B7);
numcharfalse++;
BYTE to,i,value;
char xxx[10]="ABCD";
counterr=0;
countloop=0;
cerror=0;
port_b_pullups(TRUE);
init_lcd();
enable_interrupts(global);
enable_interrupts(int_rb);
do
string_to_lcd(1,1,xxx);
} while(1);
// while(1)
// string_to_lcd(1,1,xxx);
// delay_ms(100);
Sad
Now it is ok
PostPosted: Thu Jan 06, 2005 7:16 am     Reply with quote
i must disable_interrupts(int_rb)
before loop while
Re: Now it is ok
PostPosted: Thu Jan 06, 2005 9:52 am     Reply with quote
before loop while
Sounds as though the serial input line is floating low at the processor. How is this wired?. If this line is low, the chip will generate continuous serial receive interrupts, and pretty nearly hang...
a
PostPosted: Thu Jan 06, 2005 8:56 pm     Reply with quote
i used R-pull up ready. but it still disable_interrupt(int_rb);
thank you for your reply
PostPosted: Fri Jan 07, 2005 4:02 am     Reply with quote
Check with a voltmeter, that the line is high at the processor. It really sounds too suspiciously like this line being seen as a low... :-)
Mark
PostPosted: Fri Jan 07, 2005 7:24 am     Reply with quote
Hum, doesn't this make the pin an output? But yet you are also using it as an input. Also, int_rb is more than just RB7. So "other things" could be causing this int to occur.
PostPosted: Thu Feb 24, 2005 5:59 pm     Reply with quote
[#use rs232(baud=9600, parity=N,xmit=PIN_B7,rcv=PIN_B7,bits=9)]
Looks like your xmit and rcv pin are the same pin! :([/quote]
PostPosted: Thu Feb 24, 2005 6:00 pm     Reply with quote
