if(realtime==shedule1[0])
this gives error(neumeric expression required!)
realtime and shedule1[2] are structure variables of same type
help!
Picstudent
Posted: Thu Jan 06, 2005 11:32 am
Write a function which compares them, member-by-member.
Return True if all members compare OK.
kender
Posted: Thu Jan 06, 2005 11:57 am
Alternatively your could write a function, which would compare memory occupied by the structures byte-by-byte. It will work faster then member-by-member comparison.
