Einly
PIC serial output with 16bit? |
Posted: Tue Jan 04, 2005 10:24 am |
Is that possible to send 16bit via serial port with 1 time sending command?
Or we have to send it in 2 sending commands?
What's about 10bits?
Thanks...
Regards: Einly _________________ Einly |
Posted: Tue Jan 04, 2005 10:41 am |
What about: fprintf("%ld", value) |
Re: PIC serial output with 16bit? |
Posted: Tue Jan 04, 2005 10:44 am |
Einly wrote: | Is that possible to send 16bit via serial port with 1 time sending command?
Thanks...
Regards: Einly |
No.
The UART in the PIC, only supports 8/9 bit transmission/reception. Even using two commands, you will get a stop bit after each byte. Obviously you can generate your own 'wrapper' function, to send a 16bit value, but it'll still result in two transfers. It is important to realise, that it is the word length, following the start bit, that determines the allowable timing errors between the ends. A system providing 16bit async, given the standard sampling strategy, would require baud timings closer than 2%, to be reliable. This is why most of the standard protocol formats only support 5 to 9 bits for this type of comms. 16bit transfers are common for synchronous comms, but not on asynch.
rwyoung
Posted: Tue Jan 04, 2005 1:32 pm |
Thanks...
Regards: Einly |
Do you mean the asynchrounous serial port as in the UART (USART)?
Or do you mean the synchronous serial port?
Or do you mean the SPI port?
Or do you mean the I2C port (although I seldom here people refer to that as the "serial port")?
(edited, not sure how I managed to send this without finishing...)
In all cases, the built-in hardware (found on some but not all chips) for handling these communications does not have support for more than 8 or 9 bits per "word". Note, my information may be out of date as I'm not familiar with the PIC18 or PIC10 family options.
If you want longer word lengths you will need to write your own code to "bit-bang" the interface and not use the built-in hardware. _________________ Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
jaymiller Guest
16bit serial |
Posted: Wed Jan 05, 2005 6:44 am |
I have for several years 'bitbanged' 22 bits without any problems.Used in my remote energy control systems,solves any 'hacker' from attacking or figuring out what I'm doing. |
jds-pic
Re: 16bit serial |
Posted: Wed Jan 05, 2005 4:21 pm |
jaymiller wrote: | 'bitbanged' 22 bits... |
yes, as long as the receiving entity can speak the same language.
my assumption is, however, that the original poster is somewhat of a PIC novice and is simply trying to send data collected by a PIC to a PC with the two connected via serial RS232. unfortunately there isn't much of a problem statement to go on, but that's what it appears to be. he's flumuxed because the PIC to PC communications are all byte sized, but he needs the PIC to return a value > 8 bits wide to the PC.
the real question then is whether the PC is running a program of his own design, or a commercial terminal application such as hyperterminal. if the former, the PIC can send two bytes back to back, perhaps prefaced by a preamble indicating the next two bytes are a double, or even "packetized" with a simple PIC-to-PC protocol. then, the PC executable can be modified to glue togther the two data bytes to make a 16bit value, and subsequently convert/massage/display/store as needed. however, if the PC program can not be modified, there must be some work done at the PIC to send the 16bit long data in an ASCII format which can then be simply displayed by the terminal program.
jds-pic |
