Video Level meter
mjdale2003
View user's profile Send private message Yahoo Messenger MSN Messenger
Video Level meter
PostPosted: Wed Dec 29, 2004 1:46 pm     Reply with quote
Hi, i am having trouble working out my latest project i want to measure the voltage level of a video line i know that i need to do this every 64us
to get a reliable result and the hard part is i not only need to measure the peak white level i need to measure the sync pulse voltage
firstly does any one know how to set up the timers to read the a to d at that sort of speed on an 877a and also i would prefer to do it with a 16f628a using the comparitors but i have no idea wher to start
kind regards mike
Haplo
PostPosted: Thu Dec 30, 2004 5:38 am     Reply with quote
You can use a video sync seperator chip (such as LM1881) to detect the beginning and the end of the horizontal and vertical sync pulses. During those times you can perform your measurements.
mjdale2003
PostPosted: Thu Dec 30, 2004 11:45 am     Reply with quote
The problem rearly is to remove the negative offset from the video signal itself ie lifting the signal so that it is always positive so that I can get a reading from the a to d. Does anyone have any circuit diagrams that may be of any use ?
SherpaDoug
PostPosted: Thu Dec 30, 2004 11:55 am     Reply with quote
How about AC coupling it to the midscale of the A/D. Then you just measure the tip of the sync pulse and subtract from your video reading. It seems easier than doing a real DC restoration.
mjdale2003
mjdale2003
PostPosted: Fri Dec 31, 2004 8:49 am     Reply with quote
Thanks, that works well now the only problem i have is setting up the timer to overflow every 64us could any one show me some code that will do this and also explain how to work it out for my self
Regards,
mike
Mark
PostPosted: Tue Jan 04, 2005 1:55 pm     Reply with quote
Look at the setup_timer_2() function in the help file.
At 20MHz, the timer would increment every 200ns.
If we use a prescaler of 4, then it would increment every 800ns.
To get the period value, 64us / 800ns = 80 so...
setup_timer_2(T2_DIV_BY_4, 80, 1);
