PVC160203P LCD & pic16f84a test program
Coax
PostPosted: Wed Dec 29, 2004 5:27 am     Reply with quote
Hi !
I have buyed this LCD display ( 2 x 16 ) but i can't find any schematics for pins (on the lower side you have 14 pins + K,A pins) and ond left side power (PICVUE).
Thus anyone knows which pins ( on PIC and LCD ) must i use to write
simple program like "Hello world" on LCD ?
This is the basic, but what pins to use ?
#include <16F84a.h>
#use delay(clock = 1200000) //----------12 MHZ XT
#include "lcd.c"
lcd_init();
printf(lcd_putc,"First Line");
printf(lcd_putc,"\nSecond Line");
PostPosted: Wed Dec 29, 2004 9:13 am     Reply with quote
Hi there,
you can find the datasheets here :
http://www.picvue.com.tw/Product_sn/index2_1602.htm
Regards
Michael.
Coax
PostPosted: Wed Dec 29, 2004 12:12 pm     Reply with quote
Thanx Michael !
I found the datasheets.
Can u point me how to define the pins for PIC 16f84a to make some test program for LCD ?
Thanx in advance
PostPosted: Wed Dec 29, 2004 12:53 pm     Reply with quote
Hi, here is a small quote from lcd.c file :
// As defined in the following structure the pin connection is as follows:
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
// LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
With this small text program (Your own) :
#include <16F84a.h>
#include "lcd.c"
   lcd_init();
the #define use_portb_lcd TRUE lets the compiler know that we are going to use port B
on the PIC (a PIC16F84A doesnt have a Port D that are default used) so you Pin layout will look like this :
PIC   LCD
B0    Enable
B1    RS
B2    RW
B4    D4
B5    D5
B6    D6
B7    D7
Pins D0-D3 arent used as we are talking to the LCD in 4bit mode.
Regards
Michael
mkent
PostPosted: Thu Dec 30, 2004 12:58 am     Reply with quote
Hello coax, Your #use delay(clock) is not 12 MHZ but 1.2 MHZ.
Happy New Year to all. Mick
Coax
PostPosted: Thu Dec 30, 2004 4:02 am     Reply with quote
Hi !
Thanx !. I will try it and i will send replay today or tomorrow !
p.s. Thanx for typing error, corection :-)
cambo
PostPosted: Thu Oct 11, 2007 2:26 am     Reply with quote
I also had this problem, thanks.
hoong
pls help me
PostPosted: Sat Jun 14, 2008 9:46 am     Reply with quote
can i have a full c program including all the part that i need to enter into my program so that i can test my 16x2 LCD ?? Thank... can email me to cheunhoong@hotmail.com
thx alot
