After searching for examples in setting PWM duty cycle in CCS forum, I decide to write this to seek for help.
Currently, I am using PIC18F2331 with 16Mhz crystal.
Can someone advise me on how to write the code for output a PWM on RB0/PWM0 pin with 50% dutycycle with any frequency??
Really appreciate that someone will help me.
Thanks very much.
Guest Guest
2331/2431 EPWM example
Posted: Wed Dec 29, 2004 5:50 am
This setup is a snip from working code. Don't forget to set up the TRIS register for the PWM output you're using.
