Problem with #ORG and "Invalid ORG range" error.
manex agirrezabalaga
PostPosted: Tue Dec 28, 2004 3:13 pm     Reply with quote
Hello, I work with PCH 3.203 and a 16F88 chip actually. I'm using the bootloader from www.sparkfun.com, and it asks me to put #org 0x0004 at every program in order to download the program to the chip.
#include <16f88.h>
#fuses HS,NOWDT
#use delay(clock=8000000)
#org 0x0004
ERROR : Invalid ORG range
I tried with other #ORG configurations, such as #org 0x0000,0x0004 {} and #org 0x0004,0x0FF7 but none of these get my compiler rid of the annoying error described above.
A friend of mine told me to set #build (reset=0x0004, interrupt=0x0008) and the error dissappeared, but the interrupt routines don't get working.
I was later told to set #build (reset=0x0008, interrupt=0x0004), and the INVALID ORG RANGE error appeared, with the cursor blinking at the end of the interrupt service routine. In absence of interrupts, it compiles safely.
I don't know what to do, I'd appreciate very much your valuable help.
thanks beforehand
PostPosted: Wed Dec 29, 2004 9:16 am     Reply with quote
There,
use this with Sparkfun Bootloader :
#build(reset=0x1, interrupt=0x5)
#ORG 0x0F00,0x0FFF {}
Regards
Michael.
Manex Agirrezabalaga
Re:
PostPosted: Thu Dec 30, 2004 6:20 am     Reply with quote
Thanks!! The solution works pretty well!
Best regards
manex
