Uncoupling RS232
Userrr
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Uncoupling RS232
PostPosted: Fri Dec 24, 2004 9:23 pm     Reply with quote
Please help me find easy opto-uncoupling or inductor.
I found ADUM1402 Digital Isolator with 5V supply and current - 1ma per channel. I think use this without max232 and use supply from PC.
but how make 5V from 13V - q? to convert TX,RX, and power?
How I can do this?
Thanks!
Sandman
Re: Uncoupling RS232
PostPosted: Sat Dec 25, 2004 10:40 am     Reply with quote
The ADUM1XXX chips are very nice and works well. Just keep in mind that the supply voltage on the primary and secondary side should be independent (It works in some sense with the same supply on both sides, but I have run in to interference problems when this was used.).
Also keep in mind that the digital isolator like ADUM is NOT a line driver. It means that the output current from the circuit is rather small and should only be used for onboard circuits, or with short, shielded wires since the line will be very sensitive to attenuation. The system will also be more sensitive to disturbances like EMI when no driver is used.
Driver protocol like RS232, 422 and 485 (etc.) are developed for this reason.
If you are using the PC power supply you will have 5V available. Why use 13V? If your plan is to communicate with a PC I strongly recommend you to use RS232 (keeping KISS in mind Wink ).
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Sun Dec 26, 2004 4:54 pm     Reply with quote
Also Maxim makes MAX3250, which integrate isolation and RS-232 line driver.
Nick
