ds1302 save and read problem
pcmgogo
PostPosted: Sun Dec 26, 2004 3:26 pm     Reply with quote
I write a code for drive ds1302 with pic16f84. I write the code with ds1302.c library.
I use the pic's 3 pin. My code is working with these procedure,
i use only write and read functions for ds1302.
InitRTC, init function has
write_byte(0x8e);
write_byte(0x00);
write_byte(0x90);
write_byte(0xa0);
Set time, set time is here,
write_byte(0x84);
write_byte(0x01);
write_byte(0x82);
write_byte(0x01);
write_byte(0x80);
write_byte(0x00);
Read time is here,
write_byte(0x85);
ret_hr=read_byte();
write_byte(0x83);
ret_min=read_byte();
write_byte(0x81);
ret_sec=read_byte();
Then, LCD started.
i could read only 00:00:00 (ret_hr,ret_min,ret_sec).
What is the problem.
Thanks.
PostPosted: Mon Dec 27, 2004 2:55 pm     Reply with quote
I looked at the CCS driver file, ds1302.c, and it doesn't have functions
with the names "write_byte()" and "read_byte()".
Do you have the CCS compiler ?
If so, you should use their example file for the DS1302: EX_RTCLK.C
And you should use the CCS driver: DS1302.C
