switch on 2.1v and 2.5v
Nick
PostPosted: Sun Dec 26, 2004 12:49 pm     Reply with quote
I am trying to make a switch on 2.1 volts and anther switch to turn on at 2.5 volts without using the PIC. The wire will have between 2v and 4v and I would like the switch to supply +5v for true and 0v for false. Does anyone have any pointers?
analog line
(2v-4v)________________---Switch----(+5v or 0v)
Nick
Charlie U
PostPosted: Sun Dec 26, 2004 1:14 pm     Reply with quote
I am not certain what you are trying to do, but it sounds like you could use an analog switch such as a TI CD74HC4066. Take a look at this link and see if it is what you are looking for.
http://focus.ti.com/docs/prod/folders/print/cd74hc4066.html
Or are you trying to create 0 and 5V from the analog line? In that case, you could use a comparator such as an LM393. Look at the data sheet and some of the app notes. You may want to add a bit of hysterisis to give some noise rejection.
http://www.national.com/pf/LM/LM393.html
Neutone
Re: switch on 2.1v and 2.5v
PostPosted: Mon Jan 03, 2005 9:14 am     Reply with quote
analog line
Nick
Sounds like you want a comparator circuit. You can do this with OP amps and voltage dividers. Some PIC's have comparitors built in.
