Oscillator question (12F683)
PostPosted: Thu Dec 23, 2004 3:45 am     Reply with quote
I want to use 8Mhz internal oscillator (HFINTOSC), then it is suposed I would have a 2Mhz signal in OSC2/GP4 output pin (8Mhz/4). But I have a 1.14Mhz in OSC2/GP4 pin. I have not touched the calibration word in 0x2008 and I think the fuses are programed Ok. What is happening?
#include <12F683.h>
#device adc=8
#use delay(clock=8000000)
#fuses WDT,INTRC, CPD, PROTECT, MCLR, NOPUT, NOBROWNOUT, NOIESO, NOFCMEN
   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_STATE_STABLE);
Thanks in advance!
PostPosted: Thu Dec 23, 2004 1:40 pm     Reply with quote
Can you:
1. Post a complete test program. Even if there's nothing else in main(),
then post that. (Also, please compile the revised test program and
run it on hardware before posting it.) Also, please disable the
watchdog timer in your revised test program. Use NOWDT to do this.
2. Post the version of your compiler.
PostPosted: Tue Dec 28, 2004 1:45 am     Reply with quote
I think my programmer software overwrites the oscillator calibration word located in position 2008h.
While I wait for my ICD 2 and programming module to come, could anybody test this program?
Is there a 2Mhz signal in OSC2/GP4 output pin?
Compiler V3.203
#include <12F683.h>
#device adc=8
#fuses NOWDT,INTRC, NOCPD, NOPROTECT, MCLR, NOPUT, NOBROWNOUT, NOIESO, NOFCMEN
  set_tris_a(0x0C);
  while(1) {
  } //while
}//main
