My wish for Christmas! Does Noel is here?
future
PostPosted: Tue Dec 21, 2004 11:05 pm     Reply with quote
Well, for first, merry Christmas for everybody!
Second, I wish Noel (or a good person) to provide us some code to dump the ram contents to a nice formated screen on serial port and halt.
The function could the called from an RB int or a user defined "breakpoint".
Is there anybody with free time to code it?
Neutone
PostPosted: Wed Dec 22, 2004 10:00 am     Reply with quote
Untill reciently I had never used the ICDU as a debugger. I was putting togather a new project and thought I would give it a try. The ICDU when used in debuggin mode does what you are wanting done. I really don't run the debugger very often because it is very sensitive to noise. I use a switch to turn it off and on.
#if 0    // Debugging ?
   #device ICD=TRUE
   #fuses HS,NOPROTECT,NOOSCSEN,NOBROWNOUT,NOWDT,NOSTVREN,NOPUT,DEBUG,NOLVP,NOWRT       // For debugging
#else
   #fuses HS,NOPROTECT,NOOSCSEN,NOBROWNOUT,NOWDT,NOSTVREN,NOPUT,NODEBUG,NOLVP,NOWRT       // No WDT operation
#endif
future
PostPosted: Wed Dec 22, 2004 12:50 pm     Reply with quote
Yes, but it will do without aditional costs/hardware.
And anyone can use it, if somebody dont write the code, I'll do it then I have the time.
Darren Rook
PostPosted: Wed Dec 22, 2004 12:58 pm     Reply with quote
Very simple....
int16 size;
int8 *ptr;
ptr=0;
size=SIZE_OF_RAM;
while (size--) {
  printf("%X ", *ptr);
  ptr++;
All you need to do is define SIZE_OF_RAM and maybe add some formatting. SIZE_OF_RAM includes RAM and SFRs.
future
PostPosted: Wed Dec 22, 2004 1:02 pm     Reply with quote
Yes, formating, name all system registers...
I thought about a template, where one can give a name to some adresses and the dumped info can fit in a 80x25 screen.
It will take some work, but will be nice.
Darren Rook
PostPosted: Wed Dec 22, 2004 1:43 pm     Reply with quote
Well, have fun with that..
