answare pls ?
procos
answare pls ?
PostPosted: Mon Dec 20, 2004 5:32 am     Reply with quote
i can count puls over 65536 with PIC ?
wath PIC ?
Haplo
PostPosted: Mon Dec 20, 2004 5:54 am     Reply with quote
Yes you can, use a PIC with a capture module and a fast crystal. Tell us more anout your application.
SherpaDoug
PostPosted: Mon Dec 20, 2004 7:51 am     Reply with quote
Do you just want to count more that 16 bits?
Just have a software loop check the MSB of a 16 bit counter. By the time you divide anything by 65K it is pretty slow so software can track overflows and add as many more bits to the counter as you want.
PostPosted: Mon Dec 20, 2004 1:00 pm     Reply with quote
SherpaDoug wrote:
Don't blame me I'm from a blue state
Thank God for red states.... Very Happy
SherpaDoug
PostPosted: Mon Dec 20, 2004 1:23 pm     Reply with quote
He signed in as "Guest". Must be another Red voter too ashamed to tell his name.
From the Very blue Massachusetts
Sherpa Doug
addenda
PostPosted: Tue Dec 21, 2004 2:14 am     Reply with quote
pic receive pulse from sensor
with this pulse i want define two parameters:
- instant value
-globally value of flow
i need one pic who see over 65536 pulse (ex: 99999) on lcd display
procos
my
PostPosted: Tue Dec 21, 2004 2:20 am     Reply with quote
Exclamation
Very Happy Wink
SherpaDoug
PostPosted: Tue Dec 21, 2004 8:31 am     Reply with quote
Just have a 16 bit, or even 8 bit counter counting pulses. The main software loop occasionally looks at the counter to see if it has overflowed and if so increments another software counter. You can have as many bits as you have RAM to spare.
In pseudocode:
MSB  MSB of hardawre counter
short HC = 0;   HalfCarry flag shows that we have seen MSB high
if (MSB == 1)
    HC = 1;
if ((MSB == 0)) && (HC == 1)){  //Only true the FIRST time after MSB goes to 0
    HC = 0;
    SoftwareCounter++;
