printf and last versions of pcw
GDetienne
PostPosted: Fri Dec 17, 2004 12:42 pm     Reply with quote
I have the last versions of PCW and have some problems.
To determine where are the problems I write little programs for 16F876. And I found some differences.
Here a part of my test program.
char cMin, csec;
cMin = 12;
 csec= 54;
printf(LCD_PutChar,"%02U  %02d", cMin, csec);
The printf( ) is in the while() and I increment cMin and csec each second. When the two variables come to 99, I reset to 1.
This program, compiled with version 3.163, show me 12 54 on my LCD and each second the two values are incremented. It's ok.
When I compile with versions 3.212 , 3.213 and 3.214 I see on my LCD 10 50. After 10 seconds I have 20 60 and so one. I never see 21 22 23 .... Only 20 30 40 ...
If I change the printf to printf(LCD_PutChar,"%02u:%02U", cMin, csec);
I have the same printing.
The last manual don't give a change in the parameters and the readme file don't give info. I see only this message on the CCS New version board :
 3.212  A %u and %d bug is fixed
Have somebody an answer ? Where is my mistake ?
Thanks and regard.
PostPosted: Fri Dec 17, 2004 5:48 pm     Reply with quote
You didn't provide a test program, so I made one.
Instead of having the output go to an LCD, I just have it
go to the terminal window on my PC. It works OK with
PCM vs. 3.214. Here is the output:
13   55
14   56
15   57
16   58
17   59
18   60
19   61
20   62
21   63
22   64
23   65
24   66
25   67
26   68
27   69
#include <16F877.h>
#use delay(clock = 4000000)
char i;
char cMin = 12;
char cSec = 54;
    printf("%02U   %02d \n\r", cMin, cSec);
    cMin++;
    cSec++;
Mark
PostPosted: Fri Dec 17, 2004 6:48 pm     Reply with quote
There seems to be a problem when using the lcd (lcd_putc). In the below test program, the first line prints correctly while the 2nd line is like what the posted saw.
#include <16F877.h>
#include "mylcd.c"
  char i;
  char cMin = 12;
  char cSec = 54;
  char buf[20];
  lcd_init();
    sprintf(buf,"\f%02U   %02d", cMin, cSec);
    i = 0;
    while (buf[i])
      lcd_putc(buf[i++]);
    printf(lcd_putc,"\n%02U   %02d", cMin, cSec);
    cMin++;
    cSec++;
    if (cMin == 99)
      cMin = 1;
    if (cSec == 99)
      cSec = 1;
GDetienne
PostPosted: Sat Dec 18, 2004 3:04 am     Reply with quote
Many thanks for your answers.
I agree the fact that I don't have try with a terminal on my PC.
If my test program work fine on LCD compiled with my old version, with the 3 last versions it don't.
Normaly I used %02d for this variable, %02U was just for test.
Then the problem is in the LCD routine, but only with the 3 last versions. It's what Mark say.
Now the best is to compare both version.
Thanks and have a nice week end.
Mark
PostPosted: Sat Dec 18, 2004 7:58 am     Reply with quote
To clear things up for anyone else reading this, the problem isn't per ce with the printf and its not with the lcd routine either but rather the 'glue' between them.
GDetienne
PostPosted: Sun Dec 19, 2004 7:26 am     Reply with quote
Mark, thanks for your advies about this problem.
Here follow a little test program to show the problem and to discover "the glue".
My program is :
/*  test lcd 876       pcwh 3.214*/
#include <16F876.h>
#device *=16
#fuses HS,NOWDT,PUT,BROWNOUT,WRT,NOLVP
#use delay (clock=16000000)
#define CRYSTAL_FREQ    16000000
#define LINE_1          0x00
#define LINE_2          0x40
#define CLEAR_DISP      0x01
#define LCD_D0          PIN_A0   //DB4
#define LCD_D1          PIN_A1   //DB5
#define LCD_D2          PIN_A2   //DB6
#define LCD_D3          PIN_A3   //DB7
#define LCD_EN          PIN_B6   //enable
#define LCD_RS          PIN_B7   // rs
static char cSec;
const char Title [] = "Test LCD";
#separate void LCD_Init ( void );
#separate void LCD_SetPosition ( unsigned int cX );
#separate void LCD_PutChar ( unsigned int cX );
#separate void LCD_PutCmd ( unsigned int cX );
#separate void LCD_PulseEnable ( void );
#separate void LCD_SetData ( unsigned int cX );
Main ()
   set_tris_a ( 0x00 );      // tout output
   set_tris_b ( 0x00 );
   cSec = 12 ;
   LCD_Init ( ) ;
   LCD_PutCmd ( CLEAR_DISP );
   LCD_SetPosition ( LINE_1 );
   printf(LCD_PutChar,"%s", Title);
   LCD_SetPosition ( LINE_2 );
   printf(LCD_PutChar,"%02d",cSec);
   while (true)
To reduce the code, I don't print the LCD routine.
After compilation with version 3.163 and 3.214, I have compared the difference in the asm code.
I give here only the differences. First the with PCW version 3.163
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   101
0003:  NOP
....................  /*  test lcd 876       pcwh 3.163*/
.................... #include <16F876.h>
....................  //////// Standard Header file for the PIC16F876 device ////////////////
.................... #device PIC16F876
.................... #list
.................... #device *=16
.................... #fuses HS,NOWDT,PUT,BROWNOUT,WRT,NOLVP
.................... #use delay (clock=16000000)
0032:  MOVLW  24
0033:  MOVWF  04
0034:  BCF    03.7
.................... static char cSec;
0108:  BCF    03.5
0109:  CLRF   20
.................... const char Title [] = "Test LCD";
0004:  BCF    0A.0
0005:  BCF    0A.1
0006:  BCF    0A.2
0007:  ADDWF  02,F
0008:  RETLW  54
0009:  RETLW  65
000A:  RETLW  73
000B:  RETLW  74
000C:  RETLW  20
000D:  RETLW  4C
000E:  RETLW  43
000F:  RETLW  44
0010:  RETLW  00
....................    printf(LCD_PutChar,"%s", Title);
0117:  CLRF   21
0118:  MOVF   21,W
0119:  CALL   004
011A:  IORLW  00
011B:  BTFSC  03.2
011C:  GOTO   121
011D:  INCF   21,F
011E:  MOVWF  23
011F:  CALL   094
0120:  GOTO   118
....................    printf(LCD_PutChar,"%02d",cSec);
00BC:  MOVF   21,W
00BD:  MOVWF  77
00BE:  BTFSC  21.7
00BF:  GOTO   0C4
00C0:  BTFSS  22.2
00C1:  GOTO   0CE
00C2:  MOVLW  20
00C3:  GOTO   0C9
00C4:  COMF   77,F
00C5:  INCF   77,F
00C6:  MOVF   77,W
00C7:  MOVWF  21
00C8:  MOVLW  2D
00C9:  MOVWF  78
00CA:  MOVWF  23
00CB:  CALL   094
00CC:  BTFSS  22.2
00CD:  BSF    22.3
00CE:  MOVF   21,W
00CF:  MOVWF  23
00D0:  MOVLW  64
00D1:  MOVWF  24
00D2:  CALL   0A7
00D3:  MOVF   77,W
00D4:  MOVWF  21
00D5:  MOVF   78,W
00D6:  MOVLW  30
00D7:  BTFSS  03.2
00D8:  GOTO   0E0
00D9:  BTFSC  22.0
00DA:  GOTO   0E6
00DB:  BTFSC  22.3
00DC:  GOTO   0E6
00DD:  BTFSC  22.4
00DE:  MOVLW  20
00DF:  GOTO   0E2
00E0:  BCF    22.3
00E1:  BCF    22.4
00E2:  ADDWF  78,F
00E3:  MOVF   78,W
00E4:  MOVWF  23
00E5:  CALL   094
00E6:  MOVF   21,W
00E7:  MOVWF  23
00E8:  MOVLW  0A
00E9:  MOVWF  24
00EA:  CALL   0A7
00EB:  MOVF   77,W
00EC:  MOVWF  21
00ED:  MOVF   78,W
00EE:  MOVLW  30
00EF:  BTFSS  03.2
00F0:  GOTO   0F5
00F1:  BTFSC  22.3
00F2:  GOTO   0F9
00F3:  BTFSC  22.4
00F4:  MOVLW  20
00F5:  ADDWF  78,F
00F6:  MOVF   78,W
00F7:  MOVWF  23
00F8:  CALL   094
00F9:  MOVLW  30
00FA:  ADDWF  21,F
00FB:  MOVF   21,W
00FC:  MOVWF  23
00FD:  CALL   094
00FE:  BCF    0A.3
00FF:  BCF    0A.4
0100:  GOTO   129 (RETURN)
0124:  MOVF   20,W
0125:  MOVWF  21
0126:  MOVLW  01
0127:  MOVWF  22
0128:  GOTO   0BC
....................    while (true)
And for PCWH version 3.124
CCS PCM C Compiler, Version 3.214, 26317               19-déc.-04 12:44
               Filename: C:\CCS Tests\876 lcd 214.LST
               ROM used: 318 words (4%)
                         Largest free fragment is 2048
               RAM used: 7 (2%) at main() level
                         11 (3%) worst case
               Stack:    4 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   112
0003:  NOP
....................  /*  test lcd 876       pcwh 3.214*/
011B:  BCF    03.5
011C:  CLRF   20
.................... #separate void LCD_Init ( void );
.................... #separate void LCD_SetPosition ( unsigned int cX );
....................    cSec = 12 ;
0121:  MOVLW  0C
0122:  BCF    03.5
0123:  MOVWF  20
012A:  CLRF   21
012B:  MOVF   21,W
012C:  CALL   004
012D:  IORLW  00
012E:  BTFSC  03.2
012F:  GOTO   134
0130:  INCF   21,F
0131:  MOVWF  23
0132:  CALL   094
0133:  GOTO   12B
0137:  MOVF   20,W
0138:  MOVWF  21
0139:  MOVLW  01
013A:  MOVWF  22
013B:  GOTO   0BC
There are no difference in the LCD code.
I see that :
- the code for the const char Title [] = "Test LCD"; is missing
- the code for printf(LCD_PutChar,"%02d",cSec); is totally different
- the code for printf(LCD_PutChar,"%s", Title); call to addresse 0004 not excist.
What can I do ?
I thing the only solution is send a mail to CCS....
Thanks for all what you do in this forum. Have a nice day.
PostPosted: Sun Dec 19, 2004 12:20 pm     Reply with quote
To see the code which begins at 0004, edit the 16F876.H file
and comment out the #nolist statement at the beginning of the file.
Example:
#device PIC16F876
// #nolist <- Comment out this line
Then recompile your program and look at the .LST file.
You will now see the code at 0004.
GDetienne
PostPosted: Wed Dec 22, 2004 4:28 pm     Reply with quote
Answer received today from CCS :
This will be fixed in 3.215.
Thanks.
bfmitch
A workaround
PostPosted: Mon Jan 03, 2005 9:11 am     Reply with quote
If you need to display int8 values, print them as int16 instead with the variable cast as an int16.
int8 var1;
int8 var2;
printf ( lcd_putc, "Variable1: %lu Lbs", (int16)var1 );
printf ( lcd_putc, "Variable2: %lu", (int16)var2 );
When they get the bug fixed, it'll be simple to change them to what they should be.
The problem doesn't seem to exist when using serout in 3.214. However, I seem to remember that in 3.212 it did exist in serout. It drove me crazy for about 4 hours one day. I finally decided it was an optimization issue and found a different way to do it.
If they fixed it by modifying serout instead of printf, I hope they remember to take the change out of serout when printf gets fixed.
GDetienne
Thanks.
PostPosted: Mon Jan 03, 2005 5:49 pm     Reply with quote
Thanks for your suggestion. I'll try tomorrow.
How about 3.215 ?
PostPosted: Wed Jan 05, 2005 8:35 am     Reply with quote
How about 3.215 ? Rolling Eyes
bfmitch
Just Updated Apparently
PostPosted: Wed Jan 05, 2005 8:42 am     Reply with quote
Two days ago the current version was 3.214. I haven't received an email telling me that 3.215 was available. Apparently it is now.
GDetienne
Bug solved
PostPosted: Fri Jan 07, 2005 1:29 am     Reply with quote
This bug is solved in the last version (3.215).
Thanks for you help.
