Display multiplexing
davt
PostPosted: Wed Dec 15, 2004 11:15 am     Reply with quote
Hi all Smile
I have a Pic base project with 7 segment led displays - 0.56" size.
At present I use transistors to switch the common cathodes to ground to turn the relevant digit on. Because the display is not on continuously ie. it is scanned can I dispense with the transistors and use the port pins to ground the cathodes without damaging the pic or reducing its lifespan?
Thanks.
Humberto
PostPosted: Thu Dec 16, 2004 8:10 am     Reply with quote
First answer is no.
Not sure what do you try to do, considering how cheap a transistor is.
To light-on each segment of the display you need at least 7 - 10mA,
taking the worst case, wich is to display the number '8', you need
7mA x 7seg = 49mA/digit.
Microchip datasheet spec for almost all the line stated a maximum
allowable current of 25mA for driving/sinking.
Hope this help. Very Happy
Humberto
davt
PostPosted: Thu Dec 16, 2004 8:46 am     Reply with quote
Thanks Humberto for your reply.
I do realize that the max current is 25ma but if I am scanning through the 7 seg displays they will only be on for about 2ms.
I thought that the port pins might withstand a 2ms pulse rather than be continuously on.
Dave
Humberto
PostPosted: Thu Dec 16, 2004 9:18 am     Reply with quote
Hi davt,
I´m sure that if you use a PIC output to sink such pulsed current would
work, but it´s a matter of taste + experience, I´m very conservative and
never will take the risk, just to save $0.02 in a transistor.
Best wishes,
Humberto Very Happy
drh
PostPosted: Thu Dec 16, 2004 1:09 pm     Reply with quote
If you don't use transistors AND you are debugging with an ICE or ICD, you could accidentally stop the code with the cathodes enabled and blow the PIC output. I would use transistors.
David
davt
PostPosted: Thu Dec 16, 2004 3:34 pm     Reply with quote
Point taken!
Thanks for all input. Smile
Dave
