Unable to use MPLAB
cartic
Unable to use MPLAB
PostPosted: Tue Dec 14, 2004 4:42 pm     Reply with quote
I am using PIC C compiler. I am able to compile my program in PIC C successfully, but unable to do it in MPLAB. It says invalid option +M, then starts its compilation, finishes the compilation but it gives me the following error
"Error[44] rs232.c 21 : Internal Error - Contact CCS => Code 65:5:6"
and hence says build failed. Can anyone pl. help me with this.
Karthik
Sounds like an error in your code...
PostPosted: Tue Dec 14, 2004 7:05 pm     Reply with quote
Sounds to me like you have an error in your code...post your code so we can see what you have....
Be sure to include your compiler version!
cartic
This is my code
PostPosted: Tue Dec 14, 2004 8:00 pm     Reply with quote
This is my code. The compiler version is 3.118.
#include <16F873.h>  // 2k byte ROM, 128 byte EEPROM
#device *=16 adc=10
#fuses XT,NOWDT,NOPROTECT,NOWDT,NOLVP, NOBROWNOUT, NOPUT
#use rs232(baud=9600, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7, errors)
#include <string.h>
#include <stdlib.h>
char c;
       if(kbhit())
       c=getc();
       putc(c);
Any help is more welcome, as I am struck with this error for many days.
Karthik
PostPosted: Wed Dec 15, 2004 2:25 am     Reply with quote
It compiles fine in my MPLAB v6.60.
Have you just installed or upgraded your MPLAB? If yes, then make sure to:
1) Install the MPLAB plugin from the CCS website.
2) In MPLAB under 'Project\Select Language Toolsuite' there are two options for the CCS compiler. Don't select the one called 'CCS C Compiler', but the other one called something like 'CCS C Compiler for PIC12/14/16/18'.
PostPosted: Wed Dec 15, 2004 6:49 am     Reply with quote
I think ckielstra is right because it also compiles fine for me with CCS V3.210 and MPLAB 7
Dave
cartic
PostPosted: Wed Dec 15, 2004 12:14 pm     Reply with quote
Thanks for the help. I will try installing the plugin and change the language tool bar settings and see if it works.
Karthik
