Power logger
Power logger
PostPosted: Tue Dec 14, 2004 2:54 am     Reply with quote
I'm looking for a off the shelf meter to log power consumption for my project. average 1uA with pulses of 2Amp MAX I would like to stick a meter in-line and have a log + total power consumed. Anyone seen such a device?
PostPosted: Tue Dec 14, 2004 2:42 pm     Reply with quote
I assume you're trying to figure out the expected battery life
for your project.
We had this same problem, and I just did it with a "life test".
I took a PIC demo board with a 16F877 and connected the
battery voltage on the project board to the AN0 pin on the
demo board. Then, once per hour, the 16F877 would read
the A/D value. The program then sent that value and the
event number (1, 2, 3, ... etc) to a PC through the serial port,
where it was displayed in a terminal program. After a few
days, I copied the data on the terminal screen and saved it
in a file. Then I imported it into Excel and converted the A/D
value to a voltage and displayed the data as a graph of the
battery voltage vs. time.
I think I may also have turned the A/D off, when not taking
a sample, so I could reduce the leakage current of the A/D
input pin to almost zero. That way, the A/D board would
not affect the battery life.
djpark
PostPosted: Tue Dec 14, 2004 4:59 pm     Reply with quote
It is hard to imagine exactly what application you are making, but you may find it interesting check out MAX471 or MAX472.
This high side current sensor amplifier can measure the bi-direction current flow of 3V-36V with 500uA output for 1A current, you can feed it to a resistor and measure the voltage across. Particularly MAX471 has internal 35 mili-ohm resistor and can measure upto 3A.
It is hard to find in the shop, but NewArk carries it.
-- dj
