Problem with SHT75 Humidity/Temperature Sensor
Sensorboy
PostPosted: Mon Dec 13, 2004 6:04 pm     Reply with quote
Hello ,
I am using a SHT75 humidity sensor. I am interfacing SHT75 with the MSP4301232 Microcontroller. The problem I am facing is - after writing the control byte; the SHT75 does not acknowledge proper receipt of control byte. I have verified the timings and found them to be good enough. I have also tried connecting a pull up resistor for the data line, but the SHT75 does not drive the data line low.
I am sending you a snapshot of the CRO display without the pull-up resistor. Here the data line is low after transmission of the control byte, but the data line is low after the Microcontroller release the pin and not by the sensor. I would appreciate if you could explain the problem behind this.
Also, if you give me some idea of how I would test my Humidity sensor, I would appreciate.
Regards,
Waiting for ur reply
Mark
PostPosted: Mon Dec 13, 2004 6:08 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=20865&highlight=sht75
