Program loader...
Joe Heinrich
Program loader...
PostPosted: Mon Nov 26, 2001 2:03 pm     Reply with quote
I'm using the 16F877, It will interact with a PC, (with code I write for the PC). One of the options I would like to include is the ability to replace the program code. I can see that it do-able, just not exactly sure how to get it done...I don't think this is the same as a boot loader... (correct me if I'm wrong.)
A second feature I want is the ability to replace/update only a portion (or a function) of the code. For this part I realize that this function must always start at the same address. (so the non-replaced code can find it.) and the registers the functions calls must also always have the same addresses. It is very likely that the full program gets modified and replaced but the function is still the same. This function will be created by a user(via the PC program) and therefore does not have access to the my source code or the compiler.
How do I 'anchor' registers now, so that in the future as I add/delete variables the variables critical to this function stay put? And like wise for function location?
Joe Heinrich
___________________________
Original Post ID: 1326
Re: Program loader...
PostPosted: Mon Nov 26, 2001 2:22 pm     Reply with quote
:=I'm using the 16F877, It will interact with a PC, (with code I write for the PC). One of the options I would like to include is the ability to replace the program code. I can see that it do-able, just not exactly sure how to get it done...I don't think this is the same as a boot loader... (correct me if I'm wrong.)
You should look at the #org and #locate statements in the manual
and in the example files. Also look at the C and ASM source
code for a bootloader, found here:
<a href="http://www.workingtex.com/htpic/PIC_bootloader.htm" TARGET="_blank">http://www.workingtex.com/htpic/PIC_bootloader.htm</a>
Original Post ID: 1327
Shane Rowell
PostPosted: Mon Nov 26, 2001 4:55 pm     Reply with quote
I have used the bootloader available at the included link with the ccs compiler. It works great and saves a lot of time.
-Shane
:=A second feature I want is the ability to replace/update only a portion (or a function) of the code. For this part I realize that this function must always start at the same address. (so the non-replaced code can find it.) and the registers the functions calls must also always have the same addresses. It is very likely that the full program gets modified and replaced but the function is still the same. This function will be created by a user(via the PC program) and therefore does not have access to the my source code or the compiler.
:=How do I 'anchor' registers now, so that in the future as I add/delete variables the variables critical to this function stay put? And like wise for function location?
:=Joe Heinrich
Original Post ID: 1331
Steve Sawtelle
PostPosted: Tue Nov 27, 2001 9:40 am     Reply with quote
-- The boot loader allows loading of new software (except the bootloader part of course) over the serial port, so I believe it is what you want. There are several types out there - look thru the achives as thsi comes up pretty often.
--- The same idea can be used here, except now your 'bootloader' code is actually the whole program (minus the user loaded part)
-- As indicated by other responses (ORG and LOCATE)
:=Joe Heinrich
Original Post ID: 1339
