compiler upgrade - a silly question
agrj
PostPosted: Wed Dec 08, 2004 12:09 pm     Reply with quote
Hi All,
if I upgrade my compiler, the same code should generate the same check sum for both versions?
thanks
Aryldo
Mark
PostPosted: Wed Dec 08, 2004 12:12 pm     Reply with quote
Not always. The compiler might change how it generates code (big fixes, optimizations, etc..).
agrj
PostPosted: Wed Dec 08, 2004 12:38 pm     Reply with quote
So, how can I be sure that the code generated by the new version is OK? I have to test it all again?
thanks
Aryldo
Mark
PostPosted: Wed Dec 08, 2004 12:49 pm     Reply with quote
Exactly! Why are you upgrading? If the code you have is stable, then store that compiler version with the source. You can always rebuild with that compiler version and get the same results.
agrj
PostPosted: Wed Dec 08, 2004 12:59 pm     Reply with quote
That´s exactly what I´m doing. I was just wonder when I could belive that the newer version would be good to be used!!
I´m using the 3.204 version, and everything looks fine, but how knows after all!!
thanks
Aryldo
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Dec 10, 2004 4:33 am     Reply with quote
I allways make sure I note the compiler version in the source code and do stick with a version when the product is released into the real world.
However I allways feel I should be using the latest version, must be human nature, or just me!
Will
SherpaDoug
PostPosted: Fri Dec 10, 2004 7:55 am     Reply with quote
"Better the devil you know than the devil you don't."
I am still using version 3.104 because it does what I need. When I need something this version doesn't have I will upgrade. But I will archive 3.104 with the source code of my current projects.
The PIC 10F chips are likely to cause the next upgrade for me.
Humberto
PostPosted: Fri Dec 10, 2004 8:20 am     Reply with quote
Hi SherpaDoug,
Just a curiously question, 3.104 is a typo for 3.204 or is the
actual version that you are using ?
Humberto
SherpaDoug
PostPosted: Fri Dec 10, 2004 9:20 am     Reply with quote
Nope. It is really 3.104. I ordered it to replace my 2.7xx shortly after 3.xxx came out and that is what shipped. I then upgraded but lost the upgrade to a disk failure and didn't do any C work for few months. By the time I needed C again my upgrade period had ended so I am using 3.104 off the CD ROM. My programs are pretty simple and it does what I need. I haven't seen any fatal bugs yet.
PostPosted: Fri Dec 10, 2004 1:13 pm     Reply with quote
I don't upgrade very often. I'm still using vs. 3.188 for both compilers,
even though I have the maintenance subscription for PCM.
If you a version that's working, but you want to upgrade anyway,
then you should compile your program with both versions and do
a side-by-side comparison of the .LST files in MPLAB.
Use the Window menu and select "Tile Vertically" to do this.
(First close all windows except for those two .LST files).
It takes a little while to scan the two .LST files, but if you're really
worried about the safety of the upgrade, then you have to do it.
If you notice a difference in the files in a few routines, you should
closely examine those places and confirm that the new version's
code is OK.
This method won't catch every possible problem because the new
version might have a problem with some C syntax that you're not
currently using, but at least you can convince yourself that your
existing code will work OK.
