Array addressing optimization? |
Posted: Tue Dec 07, 2004 3:50 am |
I have two different ways to address data in a buffer, one based on arrays and the other on pointers. I like the second pointer based method because it is much better to maintain, but it uses way more memory space.
Code: | int32 DateTime;
struct Header *pHeader;
char Buffer[100];
pHeader = Buffer; // Make pHeader point to Buffer
// The next line requires 40 bytes in v3.212
DateTime = EncodeTime(Buffer[1], Buffer[2], Buffer[3], Buffer[4], Buffer[5], 0);
// The next line requires 120 bytes in v3.212
DateTime = EncodeTime(pHeader->Day, pHeader->Month, pHeader->Year, pHeader->Hour, pHeader->Min, 0);
Are there any suggestions on how I can pass the variables and keep both the small memory print and readability? |
Re: Array addressing optimization? |
Posted: Tue Dec 07, 2004 4:58 am |
ckielstra wrote: | I have two different ways to address data in a buffer, one based on arrays and the other on pointers. I like the second pointer based method because it is much better to maintain, but it uses way more memory space.
char Buffer[100];
No.
The reason for the difference, is that the first version, is using constant addressess. There is no difference in accessing an array, or using a pointer, in terms of memory useage, if your first line said 'Buffer[addr]', (where 'addr' was a variable), the same code would be used as for the pointer version, and the array version. However because you code a constant in the first version (Buffer[1]), the actual address of this can be solved at compile time, rather than at runtime, and the transfer becomes the simple job of moving a byte from a known address. Conversely, using pointers, puts the whole thing into a situation where it cannot be solved until runtime, and is therefore larger.
You could consider making the array version more readable using #defines. Something like:
#define Day Buffer[1]
#define Month Buffer[2]
#define Year Buffer[3]
#define Hour Buffer[4]
#define Min Buffer[5]
DateTime = EncodeTime(Day, Month, Year, Hour, Min, 0);
Will still solve as a constant during compile, and may be more readable.
future
Posted: Tue Dec 07, 2004 5:04 am |
I use a lot of these defines.
#define Day 1
#define Month 2
buffer[Day]=1;
So the constants can be used in for other things. |
Posted: Tue Dec 07, 2004 6:34 am |
Thanks, Ttelmah and Future!
I know and have used both methods, but there is the disadvantage that a change in the data structure also requires a change in the #define's. This is error prone.
The other solution I came up with is to use a union:
Code: | union
char Buf[100];
struct Header Hdr;
} Buffer;
int32 DateTime;
pHeader = Buffer;
// The next line requires 42 bytes
DateTime = EncodeTime(Buffer.Buf[1], Buffer.Buf[2], Buffer.Buf[3], Buffer.Buf[4], Buffer.Buf[5], 0);
// 122 bytes
// 42 bytes
DateTime = EncodeTime(Buffer.Hdr.Day, Buffer.Hdr.Month, Buffer.Hdr.Year, Buffer.Hdr.Hour, Buffer.Hdr.Min, 0);
future
Posted: Tue Dec 07, 2004 7:15 am |
Can you make? Does it work?
union
char Buf[sizeof(Header)];
struct Header Hdr;
} Buffer; |
Posted: Tue Dec 07, 2004 7:28 am |
Quote: | Can you make? Does it work?
union
struct Header Hdr;
} Buffer; |
Yes, this will work too. In my case though Buf is a general buffer used for other purposes as well, so that's why I want it to be larger than the size of the Header struct. |
Mark
Posted: Tue Dec 07, 2004 6:50 pm |
Quote: | Are there any suggestions on how I can pass the variables and keep both the small memory print and readability? |
Yes
How about just declaring a structure and a buffer and just locate them at the same address.
#include <16f876.h>
#fuses HS,NOWDT,NOLVP,NOPROTECT,PUT,BROWNOUT
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
#byte PORTC=7
struct
int hour;
int min;
int sec;
int day;
}stuff;
#locate stuff = 0x30
int buf[20];
#locate buf = 0x30
byte a;
stuff.hour = 1;
stuff.min = 36;
stuff.sec = 45;
stuff.day = 7;
buf[4] = 33;
do {
} while (1);
