RS232 Interrupt
eagerstudent
RS232 Interrupt
PostPosted: Tue Dec 07, 2004 4:24 pm     Reply with quote
I am trying to use a serial port to read. I am using pins 25 and 26 of PIC16f874 since they are usart ports. Here's a test code
#include <16F874.H>
#include <stdlib.h>
#define BUFFER_SIZE 20
#BIT RCIF = 0x0C.5 //address of the rcif bit
byte buffer[BUFFER_SIZE];
byte next_in = 0;
byte tbits =0;
int dataok=0;
#int_rda
void serial_isr() {
int t;
dataok=1;
tbits=tbits+1; //counts the total number of bytes read.
buffer[next_in]=getc();
t=next_in;
next_in=(next_in+1) % BUFFER_SIZE; //% gives remainder
if(next_in==0)
next_in=0; } // Buffer full !!
int main()
enable_interrupts(global);
enable_interrupts(int_rda);
if(dataok==1)
byte inar=0;
while(tbits>0)
putc(buffer[inar]);
tbits = tbits-1;
This is all the code that I would need right? I am using hyperterminal to test and it does not read any data back. Any help is greatly appreciated. By the way, if you didn't know, I am new to PIC programming.
Thank you
PostPosted: Tue Dec 07, 2004 4:37 pm     Reply with quote
you should first enable int_rda and then enable globle inturrupt.
PostPosted: Tue Dec 07, 2004 4:47 pm     Reply with quote
Your program is too complicated for your first program.
Do something like this:
#include <16F874.h>
#fuses HS, NOWDT,PUT, NOPROTECT, BROWNOUT, NOLVP
main()
char c;
   c = getc();  // Wait for a character from the PC
   putc(c);     // Then send it back to the PC
Note: Edited to change the fuse to HS, per ckielstra's post below.
PostPosted: Tue Dec 07, 2004 4:56 pm     Reply with quote
This is not required. But it is more logical.
You are trying to implement a circular buffer, which is a good method for buffering the incomming data. Problem is that you are using the same pointer for writing to and for reading from the buffer. You'll have to add an extra pointer for reading from the buffer. You know the buffer is empty when both pointers are equal.
PostPosted: Tue Dec 07, 2004 4:59 pm     Reply with quote
#fuses XT, NOWDT,PUT, NOPROTECT, BROWNOUT, NOLVP
A slip of PCM's finger: At 20MHz you need the HS fuse instead of the XT fuse
PostPosted: Tue Dec 07, 2004 5:19 pm     Reply with quote
Actually, I modified my normal 16F877 test program to make it look like
his program and I missed that part. Thanks for catching it. Mr. Green
PostPosted: Tue Dec 07, 2004 6:39 pm     Reply with quote
I am not sure what you mean by I am using the same pointer to read and write to buffer. Thank You
eagerstudent
PostPosted: Tue Dec 07, 2004 7:47 pm     Reply with quote
I tried that simple program and it worked. It does not work if I have buffer. It does not even go into the interrupt. To check if it does go into interrupt, I had a led connected to pin C0 and setting it to high. If I pressed a key on keyboard, the led should stay on as i am not setting it to low anywhere else. Thanks in advance
PostPosted: Wed Dec 08, 2004 2:56 am     Reply with quote
Reading the data is now based on the counter 'tbits', which is used in both the ISR and in your main(), this is an error waiting to happen; the instruction for modifying tbits in main() can be interrupted by a received character and the resulting value for tbits is undefined. The common solution to this is not to use the same variables in your isr and main but use two seperate variables. The first variable is a pointer to your buffer for writing the next character in the buffer, this one you already have (next_in). In your main you introduce a similar new variable for reading the next character from the buffer, e.g. next_out.
Also your value for 'inar' is never modified, so you'll output the same character every time.
rwyoung
PostPosted: Wed Dec 08, 2004 8:34 am     Reply with quote
If you do want to use buffered I/O for the UART I suggest you study the example programs EX_SISR.C and EX_STISR.C that came with the compiler (or at least should have). The will be in the EXAMPLES directory.
If you are not familiar with C code, these look a little complicated because of the #define and #include stuff at the top but that is just there to support multiple versions of the CCS compilers.
Rob Young
