How to increase Vref to 4.5 Volts in 16F628
arunb
PostPosted: Fri Dec 03, 2004 11:19 am     Reply with quote
Compiler: PCM
MCU : PIC 16F628
ADC : MCP 3208
I am using the RA2 pin in the PIC 16F628 mcu to generate a Vref voltage for a MCP 3208 ADC.
I tried to increase the voltage level to about 4.5 Volts , but I find that the maximum I could get
was 2 Volts
The settings I used are as follows
setup_vref(VREF_HIGH | 0x12 |VREF_A2);
I tried this also
I would like to know whether the above technique is OK and also how I can increase the voltage level to 4.5 V
arun
drh
PostPosted: Fri Dec 03, 2004 12:39 pm     Reply with quote
You probably need to buffer the Vref output. It has limited drive capability. So says the data sheet.
David
PostPosted: Fri Dec 03, 2004 1:00 pm     Reply with quote
What's your version of the compiler ?
Humberto
PostPosted: Fri Dec 03, 2004 4:30 pm     Reply with quote
Hi arunb,
If you are using the MCP3208 12 bit ADC, what you need is 4.096V
as reference voltage, to get a round step of 1mV in LSB. Not 4.5V
best wishes,
Humberto
arunb
RE:
PostPosted: Sun Dec 05, 2004 11:05 am     Reply with quote
Thanks for the help. I realised that a buffer would be needed. I anyway connected an external Vref source to the ADC.
By the way what Vref value is suitable???
thanks
arun
Mark
Re: RE:
PostPosted: Sun Dec 05, 2004 11:30 am     Reply with quote
arunb wrote:
thanks
arun
I guess that depends on what voltage range you are measuring!
Humberto
PostPosted: Sun Dec 05, 2004 4:00 pm     Reply with quote
To get full 12Bit advantage of the MCP3208 -wich give you 1mV LSB- you can use the MCP1541 (4.096Volts Vref)
and you donīt need any buffer at all.
If you want to "play" with this ADC, you can use any allowed Vref.
Humberto
arunb
RE:
PostPosted: Mon Dec 06, 2004 10:13 am     Reply with quote
Thank you Humberto. I will definitely check it out..
cheers
arun
