i know that i'm a greenhorn, which could cause a very simple solution for my problem. but i can't find any solution
problem:
a led should be on for exactly 1000ms (delay_ms(1000)).
but the pin is high for about 1136ms when i use the rtcc (timer0 function with interrupts are necessary for the projekt).
/*****************************> T I M E R 0 aktivieren <*****************************/
int_zaehler=ints_per_zehntelsekunde;
set_timer0(0);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
enable_interrupts(INT_RTCC);
enable_interrupts(global);
Posted: Fri Dec 03, 2004 5:47 am
The delay_ms function doesn't account for time spent in an interrupt. So during that 1000ms your interrupt took up 136ms. You could setup a timer to count some unit of measurement (I like to use ms). Then do something like
