Patrik Berglund Guest
I2C clk frequency at 10KHz |
Posted: Thu Apr 03, 2003 6:34 am |
Hi!
How can i set the I2C clk frequency at 10Khz, i'm using a 16f877 device.
___________________________
Original Post ID: 13350 |
Re: I2C clk frquency at 10KHz |
Posted: Thu Apr 03, 2003 1:40 pm |
<font face="Courier New" size=-1>:=Hi!
:=How can i set the I2C clk frequency at 10Khz, i'm using a 16f877 device.
There are two ways.
1. You can use the hardware i2c module in the 16F877.
Use pins C3 and C4 for this. In the #use i2c statement
tell the compiler to "FORCE_HW", to enable H/W i2c.
Then, in your code, set the i2c clock speed by writing
directly to the SSPADD register.
You'll have to use a crystal of 5 MHz or less, in order to
get a frequency as low as 10 KHz. That's due to the baud rate
formula, and because only the lower 7 bits of SSPADD is used
by the baud rate generator.
The formula to calculate the SSPADD value is:
<PRE>
5 MHz
SSPADD = ---------- -1
4 x 10 KHz
</PRE>
So SSPADD = 124
To program SSPADD, use this code:
#byte SSPADD = 0x93 // Put this above main()
main()
SSPADD = 124;
// Put other code here.
The 2nd way is to use your own i2c library.
Then you can set the clock speed by controlling the
length of the software delay loops.
Peter Anderson has some sample i2c code. You can see that
the clock speed is controlled by the delay_10us() function.
To slow down the clock, just use longer delays. Also, you
don't have to use his delay_10us() function. You can substitute
the acutal CCS delay routines. He just used his own delay
function because he wanted to make the code be compiler-independent. (Even though he uses the CCS compiler).
<a href="http://www.phanderson.com/PIC/PICC/CCS_PCM/24_256_1.html" TARGET="_blank"> <a href="http://www.phanderson.com/PIC/PICC/CCS_PCM/24_256_1.html" TARGET="_blank">http://www.phanderson.com/PIC/PICC/CCS_PCM/24_256_1.html</a></a>
There is a 3rd "cheap" way, which is to change the #use delay
value so it's much faster than your actual crystal speed.
Then use software i2c. The compiler will insert more delay
loops than normal, and this slows down the software i2c clock.
I would not recommend this method, because it screws up your
delay_us and delay_ms functions. You'll always have to
remember to adjust them to give the proper delay you want.
It's not worth it. Certainly not in a real product, where
the code has to be maintained.
[Edited to correct the above paragraph, so that it says
"much faster". Ie., if you're running with a 4 MHz crystal,
set #use delay(clock=20000000) to make the delays be 5x longer.
ie., if you use delay_us(1), it will really be a 5us delay.
Again, I do not recommend doing this, for the reasons given
above.]</font>
Original Post ID: 13370 |
Posted: Fri Apr 04, 2003 12:28 pm |
:=:=Hi!
:=:=How can i set the I2C clk frequency at 10Khz, i'm using a 16f877 device.
:=There are two ways.
:=1. You can use the hardware i2c module in the 16F877.
:= Use pins C3 and C4 for this. In the #use i2c statement
:= tell the compiler to "FORCE_HW", to enable H/W i2c.
:=Then, in your code, set the i2c clock speed by writing
:=directly to the SSPADD register.
:=You'll have to use a crystal of 5 MHz or less, in order to
:=get a frequency as low as 10 KHz. That's due to the baud rate
:=formula, and because only the lower 7 bits of SSPADD is used
:=by the baud rate generator.
:=The formula to calculate the SSPADD value is:
:=<PRE>
:= 5 MHz
:=SSPADD = ---------- -1
:= 4 x 10 KHz
:=</PRE>
:=So SSPADD = 124
:=To program SSPADD, use this code:
:=#byte SSPADD = 0x93 // Put this above main()
:=main()
:=SSPADD = 124;
:=// Put other code here.
:=The 2nd way is to use your own i2c library.
:=Then you can set the clock speed by controlling the
:=length of the software delay loops.
:=Peter Anderson has some sample i2c code. You can see that
:=the clock speed is controlled by the delay_10us() function.
:=To slow down the clock, just use longer delays. Also, you
:=don't have to use his delay_10us() function. You can substitute
:=the acutal CCS delay routines. He just used his own delay
:=function because he wanted to make the code be compiler-independent. (Even though he uses the CCS compiler).
:= <a href="http://www.phanderson.com/PIC/PICC/CCS_PCM/24_256_1.html" TARGET="_blank"> <a href="http://www.phanderson.com/PIC/PICC/CCS_PCM/24_256_1.html" TARGET="_blank">http://www.phanderson.com/PIC/PICC/CCS_PCM/24_256_1.html</a></a>
:=There is a 3rd "cheap" way, which is to change the #use delay
:=value so it's much slower than your actual crystal speed.
:=Then use software i2c. The compiler will insert more delay
:=loops than normal, and this slows down the software i2c clock.
:=I would not recommend this method, because it screws up your
:=delay_us and delay_ms functions. You'll always have to
:=remember to adjust them to give the proper delay you want.
:=It's not worth it. Certainly not in a real product, where
:=the code has to be maintained.
Original Post ID: 13408 |
