| John_Lintern
				| Newbie needs help to make a lookup table |
				|  Posted: Mon Nov 29, 2004 9:51 am |   |
				| I need to use a lookup table of some sort but I have no idea how to do it !
 I need a value to be looked up from two variables, 'Throttle Position' and 'RPM'.
 Both these variables are 8-bit integers ranging from 0 to 255.
 The lookup value will also be an 8-bit integer ranging from 0 to 255.
 So I need to create a MAP, just like the fuel and ignition MAPS used in engine management control units.
 If I used a lookup table for every value of the two inputs I would have a table of 65,025 bytes !  (255*255)
 So I have reduced this by using a resolution of 5 for the 'Throttle Position' and a resolution of 4 for the 'RPM', this gives me a table of 3,328 bytes (52*64).
 i.e.
 0  4  8  12  16  20  24  28  32 ......252
 5
 10
 15
 20
 25
 255
 The values of the lookup table will probably be stored in an external eeprom at a later date.
 But for now, what is the best way for me to create a lookup table ?
 Can I use something like...
 BYTE CONST SINE_WAVE[200,100] = {
 128,132,136,139,143,147,150,154,158,161,165,169,172,176,179,
 182,186,189,192,195,199,202,204,207,210,213,215,218,220,223,
 225,227,229,231,233,235,237,238,240,241,242,243,244,245,246,
 247,247,247,248,248,248,248,248,247,247,247,246,245,244,243,
 242,241,240,238,237,235,233,231,229,227,225,223,220,218,215,
 213,210,207,204,202,199,195,192,189,186,182,179,176,172,169,
 165,161,158,154,150,147,143,139,136,132,128,124,120,117,113,
 109,106,102,98,95,91,87,84,80,77,74,70,67,64,61,57,54,52,49,
 46,43,41,38,36,33,31,29,27,25,23,21,19,18,16,15,14,13,12,11,
 10,9,9,9,8,8,8,8,8,9,9,9,10,11,12,13,14,15,16,18,19,21,23,
 25,27,29,31,33,36,38,41,43,46,49,52,54,57,61,64,67,70,74,77,
 80,84,87,91,95,98,102,106,109,113,117,120,124};
 I tried to compile my program with this code inserted but it came up with an error.
 It highlighted the 200 (in the line BYTE CONST SINE_WAVE[200,100]) and said 'Expecting a ]'.
 Can anyone offer some help ?
 PS. I am using a PIC16C74B
