Guessed Guest
I just can't breath life into my program... |
Posted: Sat Nov 27, 2004 2:13 pm |
I just can't seem to get this program to work. The output on the RS232 terminal window displays a loop of the first four characters repeatedly.
ie: BCDEBCDEBCDE...
It looks like my program keeps looping back to main after issuing the fourth command in the program listing below.
#include <16f877.h>
#include </home/guests/CP_401/F877.h>
#fuses HS,NOWRT,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP,NOCPD
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
#use fast_io(A)
//* FUNCTION PROTOTYPES
int8 GetData(void);
void DisplayTemp(int8);
//* GLOBAL VARIABLES
int8 data;
//* DEFINES
#define dataport PORTD
#define addrport PORTB
#define cntlport PORTE
#define RXDATA PIN_A3
#define IOR PIN_E0
#define IOW PIN_E1
#define RESET PIN_E2
#define AEN PIN_B4
#define LE PIN_C1
#define clr_reset output_low(RESET)
#define clr_ior output_low(IOR)
#define clr_iow output_low(IOW)
#define clr_aen output_low(AEN)
#define set_reset output_high(RESET)
#define set_ior output_high(IOR)
#define set_iow output_high(IOW)
#define set_aen output_high(AEN)
//* FUNCTIONS
GetData(void)
int16 counter;
int8 bits = 8;
int8 data;
//save timer state for return
int16 tmrcopy;
tmrcopy = get_timer1();
printf("Inside getdata\n\r");
while (!input(PIN_A3)){
delay_us(150); /* 1/2 bit time */
// high level detected - may be preamble
printf("Fell through\n\r");
delay_ms(10); /* skip over possible preamble */
set_timer1(0); /* 0.2us per tick */
delay_us(150); /* wait for bits */
counter = get_timer1();
printf("\n\rCounter: %2X \n\r",counter);
if (counter<10000||counter>16000){
set_timer1(tmrcopy);
printf("Bad Header\n\r");
return 0; /* not a valid header */
set_timer1(0);
while(bits>0){
delay_us(300); /* Starting on leading edge of data, time bits */
if (!(input(PIN_A3))){
printf("received 1\n\r");
output_bit(PIN_A1,1);
bit_set(data,0); /* set lsb of data */
rotate_left(&data,1); /* shift it to the left */
output_bit(PIN_A1,0);
} else {
printf("received 0\n\r");
output_bit(PIN_A2,1);
bit_clear(data,0); /* set lsb of data */
output_bit(PIN_A2,0);
bits--;
delay_us(600);
return data;
void DisplayTemp(int8 data)
printf("In display temp\r\n");
putc(data);
//* Start Point
setup_adc_ports(NO_ANALOGS);
putc(0x42);
setup_adc(ADC_OFF);
putc(0x43);
setup_psp(PSP_DISABLED);
putc(0x44);
setup_spi(FALSE);
putc(0x45);
setup_counters(RTCC_INTERNAL,WDT_18MS);
putc(0x46);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_4); /* 20MHz/4 = (5MHz/8)^-1 = 1 count per 1.6us */
putc(0x47);
set_tris_a(0x08);
clr_reset;
set_ior;
set_iow;
set_aen;
loop1:
putc(0x0D);
putc(0x0A);
printf("Starting Main\n\r");
delay_us(150); //wait for bits every 150us
data=0;
while(!data)
printf("Getting data\n\r");
data = GetData(); //loop until a valid data
printf("Got data \n\r");
printf(data);
DisplayTemp(data);
goto loop1;
The program seems to repeat before/during the setup_counters(RTCC_INTERNAL,WDT_18MS);
command.
I am using a pic16f877 with the ccsc compiler version 3.072 on linux. I can run sample programs on the hardware, so I have verified the hardware. Do I have to put my function prototypes after main... I don't think that should matter.... I have tried commenting out the line that starts the counter, but it doesn't seem to matter. I will look into the .lst file as a last resort.
Can anybody help me out/suggestions?
Thanks!! |
Posted: Sat Nov 27, 2004 3:07 pm |
Well, the first thing I would normally ask is, are you sure that
the Watchdog Timer is really being disabled when you program
your PIC ? I would ask what programmer you are using.
But, you mentioned you have vs. 3.072 of the Linux version of the
compiler.
Here is a thread where the guy was using Linux and he started
at vs. 3.112 (way beyond your version) and he reports 20+ bugs.
http://www.ccsinfo.com/forum/viewtopic.php?t=18884
So at that point, I would stop wondering about WDT and just
tell you to switch to the Windows version. |
Guessed Guest
Posted: Sat Nov 27, 2004 5:08 pm |
I actually bought the windows version but it will not work due to some .crg related file issues. Anyway...
I have reduced the code to:
#include <16f877.h>
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
int8 GetData(void);
int8 data;
//* DEFINES
#define IOR PIN_E0
#define IOW PIN_E1
#define AEN PIN_B4
#define LE PIN_C1
//* FUNCTIONS
//* Absolute Start Point
setup_adc(ADC_OFF);
setup_spi(FALSE);
putc(0x47);
The program never gets to the character. It's kinda shocking that both the older versions that were purchased previously just plain don't work. These versions were bought with real(not beta) funds, so you'd expect to get a real (not beta) product... Just my two cents |
Posted: Sat Nov 27, 2004 5:36 pm |
There's a problem with your test. The compiler puts a hidden Sleep
instruction at the end of main(). So your putc() statement will load
the UART with 0x47, but the PIC will be shut down before that character
ever gets sent out.
To fix this, put a while(1) statement right before the end of main().
Example:
putc(0x47);
Also, instead of using hex codes for ASCII characters, you can just
do it with single quotes, like this:
putc('G'); |
