pic16f628 pwm problems!!!!!!
nicenoise
PostPosted: Fri Nov 26, 2004 3:37 pm     Reply with quote
hello,
i have a problem with the PIC16F628 and the outputs CCP1, A3 and A4.
I use the CCP1 how PWM for control a dc motor with a MOSFET. For test i use a led, and i want to see the light intensity, this intensity tell my about the duty cycle is, but not works. The output is 5V always... when i put the duty to 0... the output is the same... and the intensity of led not change... the state not change...
another problem are the outputs A3 and A4.... A3 is always 5V and A4 not respond... i think that the problem is with the comparator setup because this pins are the comparator inputs.... i dont know what's happend...
the output A2 works correctly, it lights every second...
i put my test code here...
anybody can help me???
thanks
Alex
#include <16F628.h>
#fuses HS,NOWDT,NOPROTECT,NOMCLR,NOBROWNOUT
//#use rs232(baud=31250, xmit=PIN_A1, parity=N, bits=8)
main() {
  byte value = 0x7F;
  setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM
  setup_timer_2(T2_DIV_BY_16, 127, 1);  // f=1.2 Khz
   while (TRUE) {
     output_high(PIN_A2);
     output_high(PIN_A3);
     set_pwm1_duty(127);
     output_low(PIN_A2);
     set_pwm1_duty(0);
PostPosted: Fri Nov 26, 2004 3:57 pm     Reply with quote
What is your version of the compiler ?
nicenoise
PostPosted: Fri Nov 26, 2004 4:29 pm     Reply with quote
my version is 3.200...
now, i changed to the old 3.187 and the pwm works.... Smile
but, the outputs A3 and A4 not works... its the same problem...
what do you think??
thanks
Alex
PostPosted: Fri Nov 26, 2004 4:37 pm     Reply with quote
Vs. 3.200 should not be used. It was the first version of the 3.2xx
series, and it has lots of bugs.
The problem with pin A3 is because your test program never sets
pin A3 to a low level. Both statements set it to high level.
The problem with pin A4 is because that pin has an open-drain output.
The PIC can't drive that pin to a high level by itself. You need to add a
pull-up resistor to that pin. You can use a 4.7K resistor.
nicenoise
PostPosted: Fri Nov 26, 2004 4:54 pm     Reply with quote
ok
thanks for your help!!!!!!
