16F684 and capture interrupt
wojc0008
PostPosted: Fri Nov 26, 2004 3:10 pm     Reply with quote
I have been using the CCP_1 interrupt to cature data on a 16F876 with no problems. Now when I use the same code, compiled for the 16F684, the interrrupt will never trigger. There is definitely data on the CCP input pin. Has anyone run into this problem? My test code is below. Thanks for your help!
CCS PCM version 3.190
#include <16F684.h>
#fuses INTRC_IO, NOWDT, PUT, NOPROTECT, NOMCLR, NOBROWNOUT
long pulse_width;
#int_CCP1
CCP1_isr()
   pulse_width = get_timer1();
   set_timer1(0);   //reset timer on every edge change
    setup_oscillator(OSC_4MHZ | OSC_INTRC);
    set_tris_c (0xFF);   //set all as inputs
    setup_timer_2(T2_DIV_BY_16,78, 16);
    setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
    setup_ccp1(CCP_CAPTURE_RE);  //switch to rising edge
    enable_interrupts(INT_CCP1);
PostPosted: Fri Nov 26, 2004 3:54 pm     Reply with quote
The problem is that the following line of code is not
being compiled correctly by your version of the compiler.
The compiler is writing to the wrong register address.
Below, I have modified your original program with a new routine
to hopefully setup the CCP correctly. The changes are shown
in bold.
#include <16F684.h>
long pulse_width;
#byte CCP1CON = 0x15
#byte PWM1CON = 0x16
#byte ECCPAS = 0x17
#int_CCP1
CCP1_isr()
// This routine attempts to copy how CCS sets up the CCP
// in later versions of the compiler.
void my_setup_ccp1(int8 value)
output_float(PIN_C5);
CCP1CON = 0;
CCP1CON = value;
PWM1CON = 0;
ECCPAS = 0;
// setup_ccp1(CCP_CAPTURE_RE); // Comment out this line.
my_setup_ccp1(CCP_CAPTURE_RE); // Use this routine instead.
wojc0008
Correct!
PostPosted: Fri Nov 26, 2004 4:21 pm     Reply with quote
Thanks so much. I've been trying to figure it out and actually bought the ICD2 header for the 16f684 (which I guess I don't need now!).
Thanks so much. The interrupt works great now!
